20 Most Recent Toshiba CZ27T31 27" TV Questions & Answers
  • You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
  1. Press "MENU" on the TV until "SET UP" appears on the screen.
  2. Now press ^ or v until "FAVORITE CH" appears in purple.
  3. Now press < or > to display the favorite channel FAVORITE CH menu.
  4. You will use < or > to got between "SET and "CLEAR."
  5. So now go to "SET" and press ^ or v until you get to channel 1.
  6. If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
  • What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Toshiba CZ27T31... | Answered on Jul 20, 2011
s-video input for a better picture , or yellow jack(RCA jack) for video, then red and white for audio
Toshiba CZ27T31... | Answered on Nov 26, 2008
Try checking the AV cable. Just interchange the Audio and Video cables, and if now you get video, and no audio, problem is faulty cables. Replace.
Toshiba CZ27T31... | Answered on Oct 09, 2008
Hi redead,
I am sorry to hear about the accident!
Our PartSearch department may be able to locate a replacement remote for you. You may either visit http://bestbuy.partsearch.com or call 1-888-Best Buy™ to see if we have a remote that will meet your needs.
Thank you,
Jason,
Go Ahead. Use Us.
Toshiba CZ27T31... | Answered on Jul 16, 2008
If your Toshiba remote control is compatible, pressing the VCR button should allow you to issue the correct code.
Toshiba... | Answered on Sep 17, 2020
Use code search in your Toshiba URC to find something that works. If a search through all codes stored in the URC fails, you may have to try another one
You have not mentioned the TV model #.. If your TV does not play avi. files I am sorry to tell you it does not support moving pictures -- it only supports MP3 music files and JPEG picture files !!. Try these two to confirm.
Toshiba... | Answered on Sep 07, 2020
How old is the TV? Does it have a marketplace of apps that came preloaded? Is there a search button in that screen? If so search for the app, you can also search for Amazon prime Video App that comes with Hulu.
Toshiba... | Answered on Aug 30, 2020
The TV's main culprits to be causing this problem are "dynamic contrast" which maybe darkening the backl light in dark scenes an example a night time or a dark scene in a movie. To make the blacks be deeper (as LCD/LED TV are rubbish at blacks) or brighten it on bright scenes to make the light be lighter and once again to make the blacks be deeper so the images pop out. Also "eco lighting" this will dim or brighten the image based on the amount of light in a room in order to be saving energy. Ether way the easy fix is to turn both of these features off. You will get rid of the problem and enjoy more subtler shades of colour that would otherwise be bleached (brightend) or crushed(darkend) out..
Toshiba... | Answered on Aug 25, 2020
Place it face down on a soft blanket and remove the attaching hardware.
Toshiba... | Answered on Aug 23, 2020
Things are not so simple. Your universal remote control may not be compatible. Use code search to find out. All URCs do not contain all possible codes for all devices.
Toshiba... | Answered on Aug 11, 2020
Use code search.
Toshiba... | Answered on Jul 26, 2020
the pin code for your Toshiba tv is 0000
Toshiba... | Answered on Jul 15, 2020
Toshiba CZ27T31 27" TV Logo
Popular Tags
17 questions posted
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
lost remote
  • Televison & Video
