20 Most Recent Toshiba 32A40 32" TV Questions & Answers
TV TOSHIBA 32A40 / Vertical Problem / Horizontal line on screen
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
7/13/2017 4:21:40 PM • Toshiba 32A40... • Answered on Jul 13, 2017
manual
How do I fix the Blue tint
White balance adjustment should be done. Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
12/2/2012 12:05:52 PM • Toshiba 32A40... • Answered on Dec 02, 2012
Model 32A40. Picture
No it is not a tube problem .............hit your TV on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width, or rolls etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears normally for some time............so solution is .....TV main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer & just ask him to resolder joints .............iam from bangalore - computers, laptop, printers, etc ) ----- good TV service engineer will charge less .........
11/29/2011 9:14:25 AM • Toshiba 32A40... • Answered on Nov 29, 2011
Toshiba 32a40. The display on the screen shrinks
You've got at least one board that's gone bad. Were it mine, I'd donate it to a local charity and get a new one. The charities have volunteers and job trainees that do the repairs, and might be able to make a buck on it, while you get a tax write-off.
7/7/2011 6:04:35 PM • Toshiba 32A40... • Answered on Jul 07, 2011
Toshiba 32A40 32" TV Problem
does any one can send me the schematic of TOSHIBA 32A40? I have a vertical problem and I need to locate the vertical IC or trancistor.
I only see a horizontal line on my Tv.
thanks.
[email protected]
4/25/2009 2:53:00 PM • Toshiba 32A40... • Answered on Apr 25, 2009
2answers
Magnets in the wall
magnet can affect color of your screen you need to relocate either your tv or the speaker. you can also remove the pink tinge in the upper corner of your tv by USING A MAGNET, how? by putting this magnet to the affected area then drag going out of your casing. prior from this you need to relocate your tv or the speaker to solve tour problem
1/1/2008 11:48:04 PM • Toshiba 32A40... • Answered on Jan 01, 2008
2answers
How come my 10-year-old toshiba tv now goes to screensaver in the middle of a program I'm watching
Hi, Please factory reset your toshiba tv or update your tv settings so that the screensaver is disabled. Either of these 2 actions should help you overcome this issue. If you don't see a screensaver option on your remote, please reference the table of contents within your manual. Thank you.
11/5/2022 4:23:48 AM • Toshiba... • Answered on Nov 05, 2022
2answers
Toshiba 49L420U does not turn on
The 5 and 3.3 voltage is standby and that would be good if you get a standby light, you won't see the 16 volt unless the power supply is at full power or out of sleep mode. Look at the legend on the power board connector going to the main for something like PWR_ON, it may be marked different, but will have something about power on, you need to see just over 3 volts there when you push the power button, if 3 volts is there replace the power supply, if you don't see that go to the connector coming from the inferred board on the main board, measure the voltage at the pins, one will be 5 volts and one of the others need to change voltage when you push the power button on the remote, measure these one at a time, if none chance replace that board, if you see a change in voltage on one of the pins replace the main board.
9/14/2022 12:03:24 AM • Toshiba... • Answered on Sep 14, 2022
Toshiba TV Stuck in Standby
Are the lines always vertical or horizontal? Are they black or multiple colors?
9/5/2022 9:12:01 PM • Toshiba... • Answered on Sep 05, 2022
Hisense tv struck by lightning repair kid
Total right off unfortunately. 125,000 volts is very damaging to all the components. Claim on house insurance, some cover it.
9/5/2022 8:40:01 PM • Toshiba... • Answered on Sep 05, 2022
2answers
Trouble with Toshiba flat screen
Over time with heating and cooling of the power board the fuse holder loses tension and won't make proper contact with the fuse, remove the fuse and bend the contacts together and see if it works, if it still gives trouble replace the power supply or solder the fuse to the holder if you have a soldering iron and can do the repairs.
8/19/2022 9:59:07 PM • Toshiba... • Answered on Aug 19, 2022
2answers
Same problem, my Toshiba 26AV502R not powering on. I found the ceramic fuse blown on the power board & replaced it. The new fuse blew the instant I plugged the TV in. Any idea what is causing this?
Replace the power board if you can find one, unless you're an electrical engineer with the proper test gear high speed switching power supplies are to complex to service
8/19/2022 5:10:17 AM • Toshiba... • Answered on Aug 19, 2022
I have a Toshiba W255 VCR hooked up to a Kinivo HDMI switch via an hdmi converter to an older Panasonic plasma TV.
try a converter box that allows multiple devices
8/19/2022 4:53:45 AM • Toshiba... • Answered on Aug 19, 2022
Internet on my old Toshiba RV75
Probably you need a digibox between your internet connection and the old TV.
8/14/2022 6:47:54 PM • Toshiba... • Answered on Aug 14, 2022
Toshiba 32A40 32" TV Logo
8 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
model 32a40 picture
  • Televison & Video
