20 Most Recent Toshiba 32A42 32" TV Questions & Answers
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Toshiba 32A42... | Answered on Dec 15, 2017
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Toshiba 32A42... | Answered on Apr 16, 2014
It sounds that there is any loose solder terminals at the main board, especially with the vertical scan output section circuit. It will be best to contact any service technician to get it repaired. Gopakumar Gopalan Google
Toshiba 32A42... | Answered on Mar 10, 2014
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective - so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 (US$ 12) - iam service engineer (computers, laptops, printers,etc) - bangalore - domlur - 09986222774 - [email protected] - if you are in bangalore then you can call me for service - i think you are living somewhere in america /australia..... - problem is simple but i don't have any idea about EHT COMPONENT 's price & service charge in your place.......
Toshiba 32A42... | Answered on Apr 14, 2011
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective - so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 (US$ 12) - iam service engineer (computers, laptops, printers,etc) - bangalore - domlur - 09986222774 - [email protected] - if you are in bangalore then you can call me for service - i think you are living somewhere in america - problem is simple but i don't have any idea about EHT COMPONENT's price & service charge in your place.......i have only 1 suggestion for you - call tv service engineer from near by area ..iam sure he can solve within 3days...if he fails to repair then you think about buying NEW TV
Toshiba 32A42... | Answered on Apr 13, 2011
The manual control buttons on the PCB board inside the tv have problems,check,if the Menu button stuck in?Tries unplug,replug about an hour later to let the tv reset,see that solved ur problems.
Toshiba 32A42... | Answered on Oct 02, 2010
hi
1- unplug the AC wire
2- wait moments
3- plug the cable - if turn on lucky you. otherwise you have to bring it to repair shop
good luck
Toshiba 32A42... | Answered on Jul 25, 2010
the memory ic is out of order...plz replce it..
Toshiba 32A42... | Answered on Jan 24, 2010
This unit has a horizontal/high voltage issue. This is a dangerous circuit to work with so you should have a shop check it for you. Thanks for using fixya.
Toshiba 32A42... | Answered on Nov 11, 2009
Most likely you have a horizontal/high voltage problem. There are no user servicable parts in this set and high voltage is dangerous to work with. Have a repair shop check it for you. Thanks. These are good sets so it is worth a check out.
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Toshiba 32A42... | Answered on May 22, 2009
1-confirm sound level in tv is high.
2-confirm sound level in sound source if it is excit is in high level.
3- confirm that you did not plug any jack in headphone socket if it is exict4-remove power cord from outlet and remove the rear cover.
(often 4-6screws).4-go away far from right side of main board(because it is danger area!!!!!!!!. .
5-check for loose connector in the speaker and reconnect.
do not go any more for your safety.
Toshiba 32A42... | Answered on Mar 08, 2008
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Red led blinks on / off, TV does not turn via power button and/or remote but after 20 minutes or so it turns on and works fine
Replace R902, R901, R905, R903, R900A, Q902, and possibly the two (one small and one large) capacitors in the section labeled as the power supply. The board will be black under the components that are bad. Q902 is an NPN transistor and is hard to find.
Toshiba 32A42... | Answered on Dec 05, 2007
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
Toshiba 32A42... | Answered on Mar 20, 2007
check for bad solders on the crt socket . If it turns off again try running the tv with the crt socket off the tube but 1st try to time how it takes for the tv to turn off then disconnect the crt socket. If it does not turn off the tube may be bad, if it does not turn off check the voltages at the crt socket and see if all the voltages at the colour outputs are close to the same, if so then you have a bad tube when you connect the tube and the voltages change conciderably the tube is gone
Use code search.
Toshiba... | Answered on Jul 26, 2020
The TV's main culprits to be causing this problem are "dynamic contrast" which maybe darkening the backl light in dark scenes an example a night time or a dark scene in a movie. To make the blacks be deeper (as LCD/LED TV are rubbish at blacks) or brighten it on bright scenes to make the light be lighter and once again to make the blacks be deeper so the images pop out. Also "eco lighting" this will dim or brighten the image based on the amount of light in a room in order to be saving energy. Ether way the easy fix is to turn both of these features off. You will get rid of the problem and enjoy more subtler shades of colour that would otherwise be bleached (brightend) or crushed(darkend) out..
Toshiba... | Answered on Jul 22, 2020
the pin code for your Toshiba tv is 0000
Toshiba... | Answered on Jul 15, 2020
Toshiba 32A42 32" TV Logo
21 questions posted
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
toshiba 32a42 power light flashing
  • Televison & Video
