20 Most Recent Toshiba 36A41 36" TV Questions & Answers
The fault is with its video output stage circuit. The fault is called "one color predominant' screen. In most cases, this might be to a loose solder terminals at the video output stage circuit board. This board can be located at the neck of the picture tube, will plugged on to it directly. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Toshiba 36A41... | Answered on Nov 05, 2013
It can be replaced. Contact any service tech:.
Toshiba 36A41... | Answered on Mar 24, 2013
The symptoms you describe is the main processor controller is about to fail, when that happens the tv will eventually become unuseable. if the set is more than 5 to 10 years old you will be further ahead to replace the set.
Toshiba 36A41... | Answered on Sep 15, 2011
It seems you have a power supply circuit failure or evev control board failure, this can be fixed by a TV technical service.
Toshiba 36A41... | Answered on Mar 01, 2011
Try imputing a different toshiba code into each of the remotes. 0156, 0060, 0154. If that does not help, then unfortunately it is your tv.
Toshiba 36A41... | Answered on May 14, 2010
Is it while watching cable TV? It could very well be hum-bars which is caused by a grounding problem. Adding a ground to your cable splitter or lifting the ground at the TV (using a ground breaker) can solve this.
Cheers,
Kevin
Toshiba 36A41... | Answered on Mar 11, 2010
If it got like that gradually suspect a low emission condition on the Blue gun inside the picture tube, this condition can sometimes be fixed by running a gun cleaning procedure, this is done with a crt analyser device at a repair shop. The other cause for a no blue picture could be a Blue color output that has stopped working, the loss of blue is suddendly when the color out fails, it could also be a problem in the signalprocesing circuit. I suggest having it checked by a tech because it would be something you could not check, first because of lack of equippment and second, you would need some technical troubleshooting skills to do the job.
Toshiba 36A41... | Answered on Jan 28, 2010
Do you have a component cable hooked up to the TV? (cable with RCA connections Green/Blue/Red/White/Red)
If so you want to check that the red cable is tightly connected to both ends (TV and whatever it is connected to).
Good Luck...
Toshiba 36A41... | Answered on Jan 23, 2010
Take the TV to a TV repair person.Don't try to repair it yourself if you have no idea how to.I know it's probably not the answer you want to hear but sometimes it's best to let a qualified electronics person fix things.You know it's fixed right and you don't have to risk your life.
Toshiba 36A41... | Answered on Jun 01, 2009
Could be a horizontal output fault, faulty power supply, a simple dry solder joint or HVT. If you can hear arcing or smell an ozone odour, it will be the HVT which may cost a bit.
Without knowing the actual cause, it's impossible to say how much it would cost to fix it.... could be anywhere from $50 to $250 etc
Best to have it checked by a technician and get a quote to repair... then decide if you think it's worth it.
Toshiba is generally a reliable brand, so if you were happy with the picture quality before the fault occurred, it's probably worth repairing.
Cheers
Toshiba 36A41... | Answered on Aug 14, 2008
Do the same remotes function normally ion other Toshiba TVs? Why don't you chech this out first? There is no possibility of the TV causing the above symptom. I can only think that you are using expired batteries.
Toshiba 36A41... | Answered on Jan 12, 2008
Before condemming the infared remote receiver, make sure that you have tried and original toshiba remote control. Sometimes universals do not always work. If you do have to replace the (IRR), the main circuit board or the button assembly must be removed. The part is soldered in and has only three wires. The approximate cost of the part is around $20. You local service center would probably charge you $80 to $100 for the repair. If you have already tried a number of universals, the chances are that the(IRR is defective). Also try the code search on the universal remote sometimes this will work. Scrivitron
Toshiba 36A41... | Answered on Jun 19, 2007
Your problem is most likely caused by a cold solder joint in the vertical circuit. Normally this is easy to find and correct. The problem will only get worse over time, but not likely for more damage to occur.
Toshiba 36A41... | Answered on Feb 04, 2007
This manual is avail as a download at http://www.servicemanuals.net The first thing I would check would be the STR regulator IC in the main power supply, that is if the standby supply is good.
Toshiba 36A41... | Answered on Sep 08, 2006
Sorry to say but your tube is bad. It may be able to br rejuvinated with a CRT restorer machine but its not always the case. Good Luck
Toshiba 36A41... | Answered on Aug 29, 2006
Remove the attaching hardware.
Toshiba... | Answered on Nov 12, 2020
I haven't an answer for you - just wanted to make the observation; having voltage on a test point is no guarantee current is flowing through the circuit and for current to flow, at the other end of the circuit there must be a return, ground path or whatever.
There is a trend these days for power to be supplied to one end of a circuit and the switching or control elements to be at the other end. Commercial circuits are devious and it takes a fair amount of skill to test them and obtain meaningful results.
One problem a person has with testing a tv that is as much computer as tv, is many circuits have a level of intelligence for self protection - they sort of know if they aren't working right and can shut down. Modern thinking seems to be any lengths to prevent fire...
Toshiba... | Answered on Nov 11, 2020
Toshiba 36A41 36" TV Logo
21 questions posted
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
remote control senser failure in tv
  • Televison & Video
