20 Most Recent
SEIKI Digital SE322FS 32" LED TV 1366x768, 60 Hz, HDTV Questions & Answers
Suddenly, no picture but sound is fine. Screen is just black, remote works, but no display on screen.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
I want dish tv remotecodes for this tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
How to hook up vcr when using a cable box
That will depend upon what you want to do. If you plan to record to the VCR from the cable box, then the cable box will need to directly connect to the VCR, then the output of the VCR is connected to the TV. Unfortunately, most VCRs are analog, not digital, so you will lose HD capability (if you have it) trying to connect this way. You also cannot record one show while watching something else (you will need to be tuned to the channel you are recording). If you want to simply use the VCR to view recorded tapes, then connect the cable box to the TV as per the cable company recommendations, and then make a second connection for the VCR. Of course, your TV will need appropriate and available jacks on the rear to do this. It is difficult to give specifics without knowing the models of the cable box, VCR, and TV.
Why won't it turn on?
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
My picture went dark everthing works but screen is dark led seiki 322fs can still see picture but is dark
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Seiki se322fs won't turn on
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
SEIKI SE322FS LED TV won't turn on, but power light is on
From your description there are blown electrolytic capacitors on the power supply board,a visual inspection will show bulged burst or leaky caps.I am assuming there is no sound or pic and no visible light from the screen.I must assume you have no prior electrical service knowledge and warn of possible high voltages being present on the primary side of the power supply at the 400volt filter cap
also be sure to unplug the set before removing the back pannel
keep safe
Len...
Wiring connection diagram
Sorry but i do not know of any tv that uses ground wires,
if you mean rca cables these have coloured plugs either red,white and yellow or red blue and green,if you look into the sockets on the back of the tv you will see the matching colours
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware.
Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
