In what way is the screen broken? cracked, distorted picture, no picture but has sound?
If it is cracked. Replacement of screen is expensive. Cheaper to buy a new TV.
If Distorted. Parts linked to the screen can be the culprit. Most common part to fail is the T-con board. Main board may not be sending signal to the T-con board.
If its no picture but has sound. Back lighting has failed which could be several things that can cause that.
without any other details besides "broken" it will be hard for someone to help with diagnosing your problem. We need symptoms like. has sound but no picture. Picture has horizontal or vertical lines. part or half of the screen is black, black borders don't count. Hope the info here has, in some way, helped bring you closer to what to do with your TV.
This is a known issue with this TV. The following might resolve it:
Check Mute and Volume:
Ensure that the TV is not muted and that the volume is set appropriately. Sometimes accidental button presses can lead to muted sound or low volume.
Inspect External Speakers:
If you're using external speakers, verify their connections. Loose cables or faulty speakers can cause sound issues.
Test Different Inputs:
Connect a non-HDMI device (such as a DVD player) to the TV. Observe if the sound distortion occurs. If it doesn't, the problem might be related to the HDMI signal from your Virgin box.
HDMI Troubleshooting:
If the issue persists with the DVD player over HDMI, consider the following:
HDMI Cable: Check the HDMI cable for damage or loose connections.
Virgin Signal: Contact Virgin to inspect the signal/lines and replace the box if necessary.
Mainboard Replacement (if needed):
If the sound distortion persists, it could be due to a faulty sound processor chip on the TV's mainboard. In this case, consider replacing the mainboard.
TOSHIBA 42RV500E, 42RV500T, 42RV500Y, 46RV500E, 46RV500T User Guide (manualmachine.com)
There may be loose contact or track open in main board.So try to check the main board thoroughly where you may find the loose of connection or track open.
Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
Serial numbers don't work Judy
https://www.google.com/search?q=A10A13799C3300
They are purely a numerical identifier of when it was made, year, day, number on the shift, whether it Joe or Billy who did final inspection.
With a MODEL number I can find them easily with just 'make model manual'.
Toshiba
http://www.toshiba.com > support > content
PDF
Thank you for purchasing this Toshiba LCD TV. This manual will help you use the many exciting features of your new LCD TV. Before operating your LCD TV, please.
62 pages
Toshiba
PDF
Thank you for purchasing this Toshiba LCD TV. This manual will help you use the many exciting features of your new LCD TV. Before operating your LCD TV, please ...
62 pages
No you can't the Insignia remote is for that model television only. Companies don't make their remotes so they operate other makes of televisions. Buy a Copy Remote for the Toshiba
https://www.google.com/search?q=insignia+remote+NS-RC03A-13
The information provided suggests that there might be an issue with the main board of the electronic device. However, it's important to consider a few factors before deciding to replace the main board:
Check for Error Codes or Diagnostic Signals: Some devices have error codes or diagnostic signals that can provide more specific information about the issue. Check the device's manual or documentation for any error codes or signals associated with the flashing LED or other symptoms.
Perform a Hard Reset: Before replacing any components, try performing a hard reset on the device. This involves turning off the power, unplugging the device, and waiting for a few minutes before plugging it back in and turning it on. Sometimes, this can resolve temporary glitches.
Consult Manufacturer Support: Contact the manufacturer's customer support or refer to the product's support resources. They may be able to provide troubleshooting steps specific to your device and guide you on whether a main board replacement is necessary.
Professional Inspection: If you are not familiar with electronic repairs, consider consulting a professional technician. They can inspect the device, run diagnostics, and provide a more accurate assessment of the issue.
Check Warranty: If the device is still under warranty, replacing components yourself may void the warranty. Check the warranty terms and conditions before attempting any repairs.
Consider Other Factors: The issue might not solely be with the main board. Power supply issues, faulty connectors, or other components could contribute to the problem. A thorough inspection can help identify the root cause.
If, after considering these factors, you still believe that the main board is the likely culprit and you are comfortable with the replacement process, you can proceed with replacing it. However, exercising caution and exploring all available troubleshooting options is advisable before making any decisions.
Same issue here. I kept plugging in the TV and it would flash the logo and go black. I disconnected the LED line from the power board, plugged the TV back in and the LED's all lite up and got great picture. Turned it off and on a few times with the power switch with no problem. Left it alone about an hour, came back, got the same symptoms all over again, Flash then nothing.
I changed out the Power Supply board....same issue, Flash of logo and black screen. Probably going to heave ho the set.
This is a single standalone Remote to 7 models of Toshiba DVDs. It is not a Universal Remote.
https://spencertified.com/products/toshiba-vc-755-tv-vcr-remote-control-remote-spencertified
this OEM remote to replace your old one. It is the original factory remote for Toshiba VCR Model as well as others, and is ready to use without ANY setup. It comes with a 6 month warranty that covers all costs if it becomes defective, the peace of mind that you are purchasing this from the best source for vintage electronics and batteries!
THIS REMOTE WAS ORIGINALLY SUPPLIED WITH THE FOLLOWING MODELS...
