20 Most Recent LG 60PN6500 60" Plasma TV 1920x1080, HDTV Questions & Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
LG 60PN6500 60"... | Answered on Mar 17, 2016
John have you tryed the t.con board it sounds to be the problem B.O.Luck
LG 60PN6500 60"... | Answered on Mar 13, 2015
There are several HDTV Calibration discs available on amazon or other locations. They will walk you through calibrating all the available levels on your television. Or you can contact any number of companies that will come out and calibrate for you, however they can be quite expensive. It really depends on how hands on you want to be.
LG 60PN6500 60"... | Answered on Jan 07, 2015
Applicable codes would be found in a compatible remote control.
LG Televison &... | Answered on Sep 18, 2020
After going three for three with power boards, it is likely the problem lies elsewhere.
There may be some local source of the interference that is affecting your picture.
LG Televison &... | Answered on Sep 16, 2020
Either the soundbar is in a permanent wait state or possibly something hasn't been connected correctly
When ONE led on the strip fails, the amount of current being sent through the strip changes. It can cause the unit to sense the change in current and shut down. You can replace all the strips or you can use a meter to check the diodes and see how many failed and then replace those individually or the whole strip they are in
indicative of a bad connection on a lead or a dry joint on a circuit board. More likely the latter, the component heats up and moves.
Wrong connection. You should not be using component input on rear of TV. Use video (Y), right audio (R), and left audio (W) instead.
LG Televison &... | Answered on Sep 10, 2020
A modern tv is as much computer as tv and so contains much circuitry that is ultra-sensitive to voltage surges and spikes that often accompany power outages or electrical storms (nearby or distant).
Repair costs can sometimes be met by the power company or your domestic insurer...
You will have to use an alternate method of connection to your Techwood TV.
LG Televison &... | Answered on Sep 06, 2020
LG 60PN6500 60" Plasma TV 1920x1080, HDTV Logo
Popular Tags
4 questions posted
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
View Most Popular
  • LG Televison & Video
Most Popular Question
remove power board side 60pn6500
  • Televison & Video
