20 Most Recent
Toshiba 36HFX72 36" TV Questions & Answers
TV picture is dark
the unit flyback has 2 adustments most likly one is focus the othercontrol on the unit g2 which if slightly adjusted will bump ur brightness up
Tv flicker
First make sure the set is off, and unplug it. open the back and pull out the main board (you may have to disconnect some connectors, make sure you remember where they go, perhaps mark them with color markers) Look for bad solder joints in the power supply (where power comes into the set). There is a group of 4 diodes some cap's and resistors and a small box (the relay) it not necessary but a good idea to unsolder with some solderwick then resolder all those leades. If there is bad solder there most likely it's in other sections as well so look all around and "touch up" areas such as both horizontal and vertical. I suggest using a 25 to 35 watt soldering iron with a "medium" flat tip. I do not like soldering "guns" they get too hot. Also there is a larg transformer with a wire going to the CRT (picture tube) Do not attempt to disconnect it, this is the high voltage anode, disconnecting should be left only to a pro, the CRT can hold up to a 30K HV charge even when the set is not plugged in.
Hope this helps!
TV has cloudy, blurry haze
The two symptoms are related and are associated with the high voltage transformer,since the problem developed overnight is going to the help of a qualified technician to diagnose the cause,if you are familiar with tv service look at the horizontal output transformer for signs of damage but be careful,there are dangerous voltages present.Or be safe and call for help.
Change batteries on my toshiba se-r0001 remote
- Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
- Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
- Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
- Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
- Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
- Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
- Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
- Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
3/9/2024 3:29:56 AM •
Toshiba...
Answered
on Mar 09, 2024
Toshiba 47" flatscreen. Power up
The information provided suggests that there might be an issue with the main board of the electronic device. However, it's important to consider a few factors before deciding to replace the main board:
- Check for Error Codes or Diagnostic Signals: Some devices have error codes or diagnostic signals that can provide more specific information about the issue. Check the device's manual or documentation for any error codes or signals associated with the flashing LED or other symptoms.
- Perform a Hard Reset: Before replacing any components, try performing a hard reset on the device. This involves turning off the power, unplugging the device, and waiting for a few minutes before plugging it back in and turning it on. Sometimes, this can resolve temporary glitches.
- Consult Manufacturer Support: Contact the manufacturer's customer support or refer to the product's support resources. They may be able to provide troubleshooting steps specific to your device and guide you on whether a main board replacement is necessary.
- Professional Inspection: If you are not familiar with electronic repairs, consider consulting a professional technician. They can inspect the device, run diagnostics, and provide a more accurate assessment of the issue.
- Check Warranty: If the device is still under warranty, replacing components yourself may void the warranty. Check the warranty terms and conditions before attempting any repairs.
- Consider Other Factors: The issue might not solely be with the main board. Power supply issues, faulty connectors, or other components could contribute to the problem. A thorough inspection can help identify the root cause.
If, after considering these factors, you still believe that the main board is the likely culprit and you are comfortable with the replacement process, you can proceed with replacing it. However, exercising caution and exploring all available troubleshooting options is advisable before making any decisions.
1/17/2024 8:35:42 PM •
Toshiba...
Answered
on Jan 17, 2024
