20 Most Recent Visual Land Prestige Pro 7D 7 inch Tablet with 8GB Memory Questions & Answers
If your device did not come with a charger in the package, go to a local electronics store and you should find chargers there! If not, look here.
RadioShack
Visual Land... | Answered on Sep 06, 2015
First lesson here in charging 101: read your info on what u got. In most of them it tells you to turn it on and use it until the item you got dies then you charge it, you can turn it on if u want to see it charging but don't play on it. An it's best to do when you can watch it, so charging it overnight is NOT good, because it will be done before you wake and over charging is not good. It makes the battery weak so holding a charge gets less and less over time. Never leave your cord in the wall when it's not charging your item. Power from the wall is still running through it and slowly frying it. Thats why people go thought many cords for one item. The reason for the first battery kill and then a full charge is a stronger battery life. It gives your battery about (but don't hold me to it) a 15% increase on life. So back to your question. It depends on the item and battery life it has when u pull it from the box. In most cases battery is about half full. Plus charging from a outlet lets say to a car charging is better and faster for your item. When most battery's are being made and tested in factory's it is a outlet that is being used. So most info on timing a charge is based on info gathered From tests done from a outlet
Visual Land... | Answered on Aug 12, 2015
first try pushing reset buttom
or a hard reset hold power button and tap vol up
many small ribbon coinnectgors use a hinged bar that presses the cable down against conenctor contacts. Flip up the bar carefully with your fingernail. It will pivot upward to release the cable.
But then, some cables are not removable. They are held in place by sticky plastic tape. LDS screens often employ that concept. Best not to try to separate the cable from the glass. Unplug the cable at the circuit board end.
Visual Land... | Answered on Feb 19, 2015
You can't you will need to save the bookmark in the browser.
Visual Land... | Answered on Nov 28, 2014
If it is even possible to get a replacement battery, getting to the battery will most likely require a small Philips screw driver and possible plastic pry bars to remove the rear bezel. You can use the iPad repair guides here as a reference, plus all required tools can be purchases here. Repair Manuals for Every Thing iFixit
check if ave another contact number to reach them or if you can go to there physically
Visual Land... | Answered on May 30, 2014
go to mobile market
Visual Land... | Answered on May 04, 2014
Turn it off using Power Key, Take the Battery out and re-insert it. Then turn it on. If it works, better, else contact Customer Care.
Visual Land... | Answered on Mar 29, 2014
Visual Land Prestige Pro 7D 7 inch Tablet with 8GB Memory Logo
Popular Tags
51 questions posted
Top Visual Land Tablets & eReaders Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Visual Land Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Visual Land Tablets & eReaders
Most Popular Question
disconnect ribbon connectors
  • Tablets & eReaders
