20 Most Recent Kurio Touch 4S Handheld Questions & Answers
Why does it over heat after 15 minutes of use
depends on if you are actually usingit for 15 minutes straight, and what app/game using and what environment your in
11/2/2015 4:04:47 AM • Kurio Touch 4S... • Answered on Nov 02, 2015
How do i remember my password
Unfortunately, remembering passwords can be tough! If you end up not being able to remember, you'll have to do a factory reset. Judging by how you said it unlocks, I'm assuming you have an Android. Below is how you do a factory reset on an Android device.
10/7/2015 12:42:04 AM • Kurio Touch 4S... • Answered on Oct 07, 2015
How do you take a screen shot on a kurio touch 4s
To screenshot volume down button and power button at same time:)
7/1/2015 6:36:06 PM • Kurio Touch 4S... • Answered on Jul 01, 2015
3answers
How do i download apps from google play on the Kurio 4s
Use the Kurio App Store application on your tablet or Play Store. You cannot download Kurio apps on your computer. Your computer uses a different operating system (Windows/Mac/Linux) than your tablet (Android).
5/20/2015 6:41:32 PM • Kurio Touch 4S... • Answered on May 20, 2015
How do I fix the charger slot on my tablet? the charger wont stay in the slot
I had this problem too. You can either use an android phone charger (easiest) or you can wrap the charger around it from top to bottom, still having it plugged in.
5/16/2015 11:52:19 AM • Kurio Touch 4S... • Answered on May 16, 2015
How do i reset my kurio 4s
there's a little hole on the side. get a paper clip and stick in there until you here a click
5/2/2015 6:06:32 PM • Kurio Touch 4S... • Answered on May 02, 2015
My kurio wont finish loading how to fix
You cant factory reset it. That only works on apple.
2/25/2015 1:31:07 AM • Kurio Touch 4S... • Answered on Feb 25, 2015
How can I get a broken screen repaired?
Are you in the uk if so I can repair your broken screen for you whats the make and model of the tablet you need repaired
1/7/2015 8:57:53 PM • Kurio Touch 4S... • Answered on Jan 07, 2015
2answers
Tablet turns on but will not get past the first screen.
It obviously is bored with your presence. Try telling it an interesting story or reading it an exciting book.
12/26/2014 8:20:05 PM • Kurio Touch 4S... • Answered on Dec 26, 2014
How to download instagram on a kurio touch
I don't believe that it can work. The kurio isn't an android, apple, or windows device.
12/26/2014 7:02:28 PM • Kurio Touch 4S... • Answered on Dec 26, 2014
0answers
I went on youtube on my Kurio 4s and then suddenly it freezes it won even turn off and its hot IM FREAKING WHAT DO I DO????
Turn it completely off. The reason its hot andvfreezing up is two words, Youtube!! It ttrying to watch, download or even send. Its too Much for it to be able to do. Next time turn your device off. That will stop the Rams from jamming everything ,freezing everything. But just reboot by pressing and holding the powerbutton until the device turns off and comes back on. When it turns back on release the power button.
12/23/2014 9:13:45 PM • Kurio Touch 4S... • Answered on Dec 23, 2014
2answers
Why won't my Kurio 4s charge?
Hi, quite a few things could be the problem, 1, the battery has died....which can be revived with the proper machine, 2. depending on age, it needs to be replaced, 3. your charging port is faulty and needs to be replaced, 4. the wall plug you use can also be worn out and does not make proper contact.....I would suggest that u rather hand it in to a bona fide technician.....
12/23/2014 9:00:12 PM • Kurio Touch 4S... • Answered on Dec 23, 2014
2answers
My home screen and reset
Hi, unfortunately its a job for a technician, yr fone has to be connected to a computor to access the security setting. Its a quick job provided you have tornado cables. Take it to yr nearest trusted cellular shop.
12/2/2014 7:41:53 AM • Kurio Touch 4S... • Answered on Dec 02, 2014
Computer is not reading it now
plug it in and check under device manager if it is listed, it may show up with an error as unknown usb device, if so un-install the drivers reboot and plug it in again, if same error check with different lead. if still same errors download drivers and reinstall. if non of that works you may have a faulty conection socket.
8/30/2014 12:20:26 AM • Kurio Touch 4S... • Answered on Aug 30, 2014
Kurio
Hi, I have not had the pleasure of holding one in my hand.....but I am sure that if u play around on the fone u will find quite a lot it can do....select the control panel icon and browse. .if u not sure what u doin...just hit the return icon and start again.....
7/25/2014 11:15:19 AM • Kurio Touch 4S... • Answered on Jul 25, 2014
Kurio Touch 4S Handheld Logo
111 questions posted
Top Kurio Tablets & eReaders Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Kurio Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Kurio Tablets & eReaders
Most Popular Question
went youtube kurio 4s suddenly freezes
  • Tablets & eReaders
