20 Most Recent Insignia - Flex 10.1" Tablet with 16GB Memory Questions & Answers
Insignia flex android stuck in safe mode. powering it off did not help.
it has a pin hole reset find the pinhole an hold pin in for 15secs and it will reset as new
1/5/2019 4:28:59 AM • Insignia - Flex... • Answered on Jan 05, 2019
2answers
Running slow need a performance enhancer
try to uninstall unnecessary apps
4/29/2017 9:51:42 PM • Insignia - Flex... • Answered on Apr 29, 2017
2answers
Sd card format ntsf or fat32
FAT 32 is more universal for transfers.
10/16/2016 3:32:29 AM • Insignia - Flex... • Answered on Oct 16, 2016
Insignia tablet won't turn on
Probably defective tablet. Here is some good advice, return it or throw it away and spend the $200 on a google nexus 7. Insignia is one of the worst electronics manufacturers in existence. No joke.
5/24/2016 7:58:35 AM • Insignia - Flex... • Answered on May 24, 2016
Will not turn on
If it is not down to a dead battery, (many batteries show that they charge full but they cannot hold that charge so they no longer switch on,) I would search on line for a method to hard reset the device. Remember that if you do go down that road you may lose any data stored on your device. Try the battery first. GOOD LUCK CARLOS
11/5/2015 9:56:41 PM • Insignia - Flex... • Answered on Nov 05, 2015
2answers
Tablet won"t charge with charger
Make sure you are using the charger that came with the unit. Wiggle the cable in the USB port on the tablet to make sure you have a connection and that it isn't a faulty USB cable or that the USB port is failing. Try using a different charger that will deliver 5 Volts at 2 Amps...no less. If none of these solutions work, return the unit to the GeekSquad Bench and have them look at it.
5/7/2015 7:38:32 PM • Insignia - Flex... • Answered on May 07, 2015
I connected the HDMI cable but there is no video, only audio. What's wrong?
Go to SOURCES on the menu, find HDMI and click on it. Go out of menu, you should see picture, no?
4/3/2015 8:02:49 PM • Insignia - Flex... • Answered on Apr 03, 2015
Why wont my tablet lock and the volume keys won't work?
in settings, try to put the "sleep" timer to 2 minutes, and see if it actually locks (or sleeps:turn off the screen)... also with mine sometimes the "capture screeen" feature works (more donts than do's!) perhaps very poor quality from the buttons. clean all the apps running, and start with a full fresh boot (turn off by holding the power button 10 secs or more, then conecting to the charging usb, press again the power button), the volume also can be set via software, again in settings.
12/3/2014 6:04:11 PM • Insignia - Flex... • Answered on Dec 03, 2014
How to reset insignia flex 10.1
Basic reset or complete "back to original out of box"? Basic resets are by either inserting a straightened paper clip into the reset hole on the side of the unit, or by pressing the volume up or volume down button AND the power button. Back to out fo box is going into settings - backup & reset, and choosing factory data reset. This will wipe out your account, data, apps, everything...just like you took it out of the box the day you got it.
6/30/2014 9:46:21 PM • Insignia - Flex... • Answered on Jun 30, 2014
Need to hard reset insignia flex
There are two options for resetting the Insignia FLEX: 1) Insert a straightened paperclip into the reset hole on the side of the unit. 2) Hold down the volume up or down key while pressing the POWER button.
6/30/2014 9:37:50 PM • Insignia - Flex... • Answered on Jun 30, 2014
How can i recalibrate my tablet
This unit does not have a screen calibration app. Recomend returning the unit to exchange for another.
6/30/2014 9:28:08 PM • Insignia - Flex... • Answered on Jun 30, 2014
0answers
0answers
Insignia - Flex 10.1" Tablet with 16GB Memory Logo
28 questions posted
Top Insignia Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
WTF Chuck.....
WTF Chuck.....
Dariusz Zalewski
Dariusz Zalewski
Are you an Insignia Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Tablets & eReaders
Most Popular Question
running slow need performance enhancer
  • Tablets & eReaders
