20 Most Recent Amazon Kindle Fire HDX 7 Questions & Answers
your internet is not good enough,THAT is the problem
Amazon Kindle... • Answered on Aug 25, 2018
If your kindle are frozen and won't turn off so, firstly reboot your kindle this is done by pressing the side button minimum 20 to 40 second and screen are blinking so, give the kindle about one minute to start backup. What to do when Kindle Stuck on the Start screen maxresdefault-ktebadcyjbdvgb0hr3tivu0f-1-0.jpg
Amazon Kindle... • Answered on Jun 18, 2018
Brenda, Check the attached links, "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." How to Reset Locked Kindle Fire Kindle Fire HD how to reset when locked up EpicReviewsTech CC when ur locked out of ur kindle how do reset it Kindle Fire Password Remove
Amazon Kindle... • Answered on Apr 18, 2018
sounds like you did everything right could call amazon see if they can help or do a factory reset to eliminate software problems you will lose all your data then there is hardware problems dead battery that won't recharge bad cable connection inside kindle Reset Kindle Fire When it Won Turn on or Charge
Amazon Kindle... • Answered on Mar 21, 2018
  1. Make sure the Kindle is turned ON. ...
  2. Press the Power button for at least 20 seconds. ...
  3. Wait for it to reboot - wait a minute or two. ...
  4. Your kindle should be back to a responsive state.
  5. You will have to go through the setup again and then synchronize to put your e-books and other data back on the device.
Amazon Kindle... • Answered on Oct 02, 2016
Try a different battery charger.
Maybe you are using a battery charger of a phone.
They have the same plug but different Amperage.
Usually tablets have more powerful battery charger than phones (2.1A instead of 0.5/1A).
The battery charger that you are currently using seems to have enough power just to keep your tablet alive, but not enough to charge it.
You can check on the data written on the battery charger's body the maximum amperage.
Amazon Kindle... • Answered on Jul 16, 2016
James, You have to make sure the Kindle is charged, try holding the button longer, maybe even up to a minute, hopefully that will do it. Check the attached links,instruction and guides, Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." You can also do a search on google for this issue, seems there is a lot of info. on this problem. Kindle Fire HD how to reset when locked up EpicReviewsTech CC 12 major Kindle Fire problems and how to fix them My kindle won turn on Is it the battery Kindle Fire HD HDX will not boot
Amazon Kindle... • Answered on Jun 19, 2016
micrasoft need wifi to setup internet
Amazon Kindle... • Answered on Jun 06, 2016
To buy content and deliver it to your device, you'll need to connect to a wireless network and register your Fire tablet to an Amazon account. Registering also allows you to transfer purchases between devices and Kindle reading apps. To learn more about connecting to a wireless network, go to Connect Wirelessly.
  1. From Home, swipe down from the top of the screen and then tap Settings.
  2. Tap My Account.
  3. Tap Register.
    • If you already have an Amazon account: Enter your Amazon account information, and then tap Register.
    • If you do not have an Amazon account: Tap Create Account, and then follow the instructions to set up a new account.
Amazon Kindle... • Answered on May 01, 2016
The following is a good place to start: Fire Kindle User Guides
Amazon Kindle... • Answered on Apr 24, 2016
Marvin, You could try registering it on a computer, or it may already be registered. Best to contact Amazon to help sort out the register error. Check the attached links,instruction , forums and guides, Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." http://www.amazon.com/gp/help/customer/display.html?nodeId=201539930 Kindle will not register 12 major Kindle Fire problems and how to fix them HELP Kindle won register and Amazon won help MobileRead Forums
Amazon Kindle... • Answered on Apr 12, 2016
Hi try another charger could B an intermittent fault with charger.if it's not the charger it could B a fault in the tablets charging circuit or a faulty.,,,, battery good luck
Amazon Kindle... • Answered on Mar 08, 2016
Amazon Kindle... • Answered on Mar 06, 2016
If you need to install Google play on your Kindle Fire HD, root your Kindle Fire device at first. However, you can't root it like other Android device with one click rooting tool - iRoot, Framaroot, Kingo Root... The rooting process may be a little complicated while it's effective and safe. For more detailed instruction, please refer to: http://www.iroot.com/how-to-articles/how-to-root-kindle-fire.html Afterwards, install the Google play. Open run.bat. Choose option 6 and install it. install-googleplay-store-app-3dm3wk5h5rf4q2suhw3cwikl-1-0.jpg
Amazon Kindle... • Answered on Mar 04, 2016
The best way is contact Amazon. Amazon.com, Under the search bar you'll see a list with help at the end. Click on help, click for devices(top right on list.) Click on you device that you have questions about. The next page on left side shows Contact Us. Click that and fill out info on problem. Then you can choose to get answer by email or phone. I usually opt for phone contact. They will call you ASAP which is usually fairly quick. You avoid all the bouncing from agent to agent until you reach the right level tech for your problem. Also no hold time. Then they will talk you through any fixes. If they don't work you may have to return it to Amazon for repairs.
Amazon Kindle... • Answered on Mar 02, 2016
Amazon Kindle Fire HDX 7 Logo
Popular Tags
87 questions posted
Popular Products
Top Amazon Tablets & eReaders Experts
Jax Planet
Jax Planet
Sheldon Dedek
rostit
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Amazon Tablets & eReaders
Most Popular Question
tablet charge screen icon shows charging
  • Tablets & eReaders
