20 Most Recent
Belkin NetCam HD Wireless Camera Questions & Answers
Reset login password
Unplug it.
Look for a little tiny hole on the camera, and put the end of a paper-clip into that hole.
Press it in there for 30 seconds.
It should reset to "admin" for the password.
Forgot server username and password
If you have it synched to your PC Lap Top,
You should find it in the hard wear on them,
or should show server when plugged in.If you
have to sign in,l do not see why, then click on
forgotten pass word.The should ask for e-mail
which YOU type in,and they will send mail for you
to change it.
LUCK
Camera is new however it has gone blurry.
Probably condensation in the lens. They aren't suitable for locations where there is high humidity and rapid temperature changes. Try drying them out with a warm hairdryer.
I have secure belkin router
naumita,
To reset a router to the factory settings:
1) Leave the router plugged in and on.
2) Locate a pin size hole; usually on the back or bottom.
3) Use a paperclip sized item and insert it into the pin hole and press in and hold for ten seconds.
4) Leave the router on and do not restart. Give it a few minutes to fully reset.
-Chris
My doorbell has gone quiet
It may have this silent option in either choice for volume or melody. My doorbell has numbered buttons that need to be pressed together with the button to open the door, in order to access these functions.
Another thought is that a battery needs to be replaced.
