20 Most Recent
Facebook 50 Gift Card for Facebook Games and Apps Questions & Answers
When i try to play
press "select" to show the "m33 VSH menu" and go to "umd iso mode" and change it into "m33 driver"..........
Objects need to touch to interact
It sounds like you may be experiencing an issue with your video game console or game. Can you please provide more information about the specific game or console you are having trouble with? This will help me provide you with more specific troubleshooting steps. Thank you.
Can I connect a USB gamepad to my tv
Whether or not you can connect a USB gamepad to your TV depends on the specific model of your TV and the type of gamepad you have.
Many modern TVs have USB ports that you can use to connect various devices, including gamepads. If your TV has a USB port and supports input from gamepads, you should be able to connect your USB gamepad to your TV and use it to play games or navigate menus.
To connect your USB gamepad to your TV, you will need to plug the USB cable into the USB port on your TV. You may also need to adjust some settings on your TV to enable gamepad input or to map the buttons on your gamepad to the appropriate functions on your TV.
It's important to note that not all TVs support gamepad input, so it's a good idea to check the documentation or manufacturer's website for your TV to see if it supports this feature. Additionally, some gamepads may not be compatible with certain TVs or may require additional software or drivers to work properly.
What is the Cheat Code to Turtle Knock please?
Turtle Knock Cheat Code 1: neverrunoutofshots - unlimited shots
LiteracyPlanet on Twitter: "Block Stack Cheat Code 1: stickyblocks - makes the blocks stick together http://t.co/SAuVXW3y"
There is five lights and three beeps what does that mean
It's important to consult the user manual of the Fortress 1700 mobility scooter or contact the manufacturer for more information on the specific meaning of the five lights and three beeps. They will be able to provide you with the information you need.
It's also important to check the mobility scooter's warranty status and the manufacturer's instructions to ensure that the repair or replacement will not void the warranty.
Keep in mind that troubleshooting and repairing electronic equipment can be dangerous if you are not familiar with the proper procedures. If you are not comfortable with performing the troubleshooting yourself, it's best to contact a professional technician for assistance.
Error code 80023101 on the
This seems to be a fairly common problem with certain PS3 updates. I would suggest you try to change your password for the PlayStation Network (PSN). Make sure you enter a complete new password and not a variation of your current one. This should fix the problem. Good luck!
How to beat 'ST Math', the game please?
Question edited for clarity and how the game is actually written.
Like 'cheats' to it? It would be better to learn mathematics and get the enjoyment of beating it fair and square. Although much of what you learn in math is little use in adult life, when you want to measure a room area for laying tile, or how many cubic feet of topsoil you need for your garden to get a 3" layer, you will be glad you know basic math. The experience of a 70 year old!
My ecco 32 has sound bt no pictures its white
There could be several reasons for this issue, and it would be helpful to know more about the specific model of your TV and any troubleshooting steps you have already tried.
Here are a few possible causes of the issue you are experiencing:
- A faulty HDMI cable or port: If you are using an HDMI cable to connect your TV to another device (such as a cable box or streaming device), try using a different HDMI cable or port to see if that resolves the problem.
- A problem with the TV's display: If the TV's display is damaged or not functioning properly, it could cause the picture to not show up. This could be due to a hardware issue and may require professional repair.
- An issue with the TV's settings: It's possible that the TV's picture settings may be set to a mode that is causing the picture not to display. Try going into the TV's settings and checking the picture mode to see if that resolves the issue.
C4070 ACCURIO PRESS CONTROLLER UNCONECTED
It sounds like you are having an issue with your Accurio Press controller becoming unconnected or disconnected. There could be a variety of reasons why this is happening, so here are a few steps you can try to troubleshoot the issue:
- Check the connections: Make sure that all the cables and connections between the controller and the device it is controlling are securely plugged in and functioning properly.
- Restart the controller: Try restarting the controller by power cycling it. To do this, turn off the power to the controller, wait a few seconds, and then turn it back on.
- Check for updates: It's possible that there may be a software update available for the controller that could fix any issues you are experiencing. Check the manufacturer's website to see if there are any updates available.
- Check for interference: If you are using a wireless connection, make sure that there is not any interference that could be causing the connection to drop. This could include other devices operating on the same frequency or physical barriers such as walls.
