20 Most Recent Samsung Galaxy S4 Mini Questions & Answers
2answers
Lycamobile simnetwork unlock pin
How do i found my puk code number lycamobile
2/27/2020 8:16:08 PM • Samsung Galaxy... • Answered on Feb 27, 2020
2answers
Charging paused battery temperature too low
The Samsung cells have four contacts. Two are for the voltage (sometimes marked as + and -) and two are for the temperature sensor. If the sensor is not communicating, the phone will detect an error and report it as low temperature. Try using a new cell and see if the message returns. If not then the old cell has a bad sensor. But if it returns, check that the four golden spring contacts in the phone are good, not bent, and the same length. If one of the contacts is bent, have it fixed.
5/18/2019 4:10:29 AM • Samsung Galaxy... • Answered on May 18, 2019
How do I unlock galaxy s4 mini sch-r890?
Try this link: http://www.android.gs/how-to-sim-unlock-samsung-galaxy-s4-for-free/
1/31/2019 3:30:50 PM • Samsung Galaxy... • Answered on Jan 31, 2019
Why cant I switch on my phone after used 5min ago can not do a hard or soft reset
Have you tried this: Turn "OFF" the phone. Then Press & Hold two keys: Power Key + Volume Up Key) for 30 seconds. If this does not work, try the Volume Down Key. Thanks Sunny
10/12/2016 6:01:41 AM • Samsung Galaxy... • Answered on Oct 12, 2016
0answers
My phone has suddenly started getting quite warm and the battery is only lasting about half as long between charges, probably due to the heat it is producing. Any ideas about why this is happening ?
It is a known problem with the Samsung Galaxy S4. There are many many complaints with fewer solutions. It is said to be more or less normal for this to happen if you are gaming or using some other app which loads up the CPU. If it happens in standby or just using the OS to read messages etc, it is a fault. Navigate to Settings-Applications-Battery Use to see what is draining the battery most. If it is the OS, like....... Standby Display Idle System OS then the battery would appear to be dying, developing a high internal resistance. If most battery is being used by Apps, then it is normal. .
11/6/2015 5:47:55 AM • Samsung Galaxy... • Answered on Nov 06, 2015
Is gps available on this phone?
Yes...
10/13/2015 1:51:49 AM • Samsung Galaxy... • Answered on Oct 13, 2015
Screen has done dark. Appears phone is on as it buzzes
could be a blown screen/ digitizer, take to your service provider for confirmation.
10/13/2015 1:38:33 AM • Samsung Galaxy... • Answered on Oct 13, 2015
Fone will not import facebook pics to contactd
Phone? Contact support
10/6/2015 2:54:02 PM • Samsung Galaxy... • Answered on Oct 06, 2015
2answers
My sound setting is at max but it is still so quiet it can hardly be heard
Manufacturing error, if you got the phone with in a year you are still within the manufacturers warranty and can have your phone replaced through samsung.
8/4/2015 1:30:05 PM • Samsung Galaxy... • Answered on Aug 04, 2015
Does photo storage drain battery quicker?
Dear Avril, Photos storage will not affect Battery.
  • Most likely you have a few or a lot of Apps running in the background depending on the application(s).
  • Check & remove Unnecessary Apps. The usual culprits are Social network Apps & Excessive Notifications.
I have included a link to manufacturer's website Good Luck JP Global Download Center
6/25/2015 5:13:36 PM • Samsung Galaxy... • Answered on Jun 25, 2015
I have the IME number and the original box for my Samsung galaxy S4 mini, but lost the phone. How do I find the serial number?
your IMEI is the Same number on the BOX which is your serial number for your phone
6/9/2015 10:55:50 AM • Samsung Galaxy... • Answered on Jun 09, 2015
Phone was charging, went out now won't turn on at all ..... Is there a way to take out the battery
It is simple enough. Here is a youtube video that shows you. https://www.youtube.com/watch?v=RAcHhVbJjIo
3/12/2015 2:08:52 AM • Samsung Galaxy... • Answered on Mar 12, 2015
My Samsung S4 mini went in for repairs. The sim card was removed for this and the device is locked. I need to enter my PIN to unlock it. Please help.
Get your card back. If not do a factory reset. 1.Power off your phone 2.Press together volume up + home button + power button 3.Release your fingers of the phone when Samsung logo appear 4.Choose with volume buttons "wipe data/factory reset" and select it with power button 5.Choose "yes" with volume buttons and select it with power button 6.Wait untiil format is complete 7.Select "reboot" 8.Wait until the phone restarts That's it!
3/3/2015 4:51:50 PM • Samsung Galaxy... • Answered on Mar 03, 2015
How do I call Asia on my phone
There are locked and unlocked versions of this phone. If you have an 'i' in your model number then you have to call your provider to fix this problem. Singapore area/country code is (+65). If you don't have the 'i' in your model number then I'm afraid you might have a greater issue, again your phone provider will be able to help you.
2/27/2015 4:18:36 AM • Samsung Galaxy... • Answered on Feb 27, 2015
How do i turn off weather updates
go to apps management find weather app and deactivate
2/13/2015 5:53:14 AM • Samsung Galaxy... • Answered on Feb 13, 2015
Why can't I download iTunes to my new Samsung mini s4 ? Am ****** !!
itunes is only used for Apple devices. A Samsung Galaxy, doesnt matter what model it is, its based of an Android platform, making it impossible to install itunes on it.
11/2/2014 5:31:00 AM • Samsung Galaxy... • Answered on Nov 02, 2014
How do I verify my phone number for Google+ using the http code given?
how to verify gmail youtube without using a cell phone
10/24/2014 7:53:51 AM • Samsung Galaxy... • Answered on Oct 24, 2014
Samsung Galaxy S4 Mini Logo
27 questions posted
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Galaxy Samsung
  • Galaxy Samsung
Most Popular Question
phone suddenly started getting quite
  • Cell Phones
