20 Most Recent
Panasonic Panafax UF-490 Plain Paper Laser Fax Questions & Answers
I lost the printer cable (to PC) of Panafax
What you need is a
PARALLEL printer cable.
They come in various lenghts, 6 feet being the most common.
Every computer store has them. Their price is around $10.00
No decorator colors, sorry. .
6/1/2011 3:17:06 AM •
Panasonic...
Answered
on Jun 01, 2011
Our fax machine has been
the drum is green roller in housing with toner, you should order the drum cartridge for your fax. With new drum you get the how to manual also. Follow the procedure.
NOTE THAT THE DRUM UNIT IS SEPARATE FROM TONER UNIT.
Hope that helps!
10/20/2010 7:32:14 AM •
Panasonic...
Answered
on Oct 20, 2010
Clear memory for the fax machine panasonic uf490
Hi
Right!!!
Press 'Function' then 7
Press 'Monitor' seven times
Press '*' (star)then 0
This Gets you into service mode.Scroll down on using Large Round Button until you get one that says Ram Initialize press Start then Scroll down unitil you see All job Clear,then press start again,M/c will reboot and this should clear your memory.
Powerdown once then your memory% should disapear
Good Luck!!
9/21/2010 9:17:21 PM •
Panasonic...
Answered
on Sep 21, 2010
Black line on copies
press function 6-4 start and let that print .. if you have no lines then the machine is the scan glass..
to clean scan glass open the control panel door but not the toner door.. you will see 2 green plastics on either side of the machine.. press them both towards the center and lift..when done properly you will lift the white plastic plate about a 1/4 inch.. tilt that up and clean the glass with windex or alcohol..
if this does not work you need a tech because you scratch the glass
7/14/2010 8:06:25 PM •
Panasonic...
Answered
on Jul 14, 2010
How do I turn off ECM on my Panasonic UF-490
press function
press 7
press monitor key 4 times slowly
* "start button"
should say service more
press 1
press 20 then start
press 1 for invalid / off
then press start
then unplug and plug back in the machine
7/14/2010 7:56:06 PM •
Panasonic...
Answered
on Jul 14, 2010
Replaced toner but continues to say replace toner&power failure 8
Anthony here. Had a similar problem, fax didn't detect the new toner. The photo sensor does not detect the toner en the fax is new. Put a black tape where the toner slots into the sensor en walla it worked. When the copies become faint I know that the toner is low or over.
A.K (Nairobi, Kenya)
4/7/2010 9:59:46 AM •
Panasonic...
Answered
on Apr 07, 2010
