20 Most Recent Panasonic Panafax UF-790 Plain Paper Laser Fax Questions & Answers
Call 1800-211-7262 for Panasonic's capable Technical Support; be sure to have the serial number of the product ready. You may be transferred or given a number for the Business Solutions Dept.
Panasonic... • Answered on Mar 05, 2015
Press the MONITOR KEY
Press the LEFT ARROW BUTTON
Press MONITOR again.
To lower the RINGER VOLUME
Press the LEFT ARROW button.
Panasonic... • Answered on Mar 24, 2014
Fax forwarding You might want to set up fax forwarding if you are going on a trip, but still want to receive your faxes while you are away. There are three fax forwarding settings:
  • Off (default)
  • Forward-When your All-In-One receives a fax, it holds it in memory and then sends it to the fax number that you designate.
  • Print and Forward-Your All-In-One forwards the fax to the designated fax number and prints the fax.
To set up fax forwarding:
  1. On the control panel, press Fax.
  2. Press Options until Fax Forward appears, and then press Select.
  3. Use the arrow buttons to scroll to the option that you prefer (Fax Forward or Print and Forward) appears, and then press Select.
  4. Enter the number that you want to forward the fax to, and then press Select.
Fwd now appears on the bottom left corner of the display.
Panasonic... • Answered on Dec 16, 2010
is the toner in the machine a ug5510 or ug5580 .. becuase those are the only 2 that will fit.. if those are correct you need to prop up the little black button you see attached to the silver bracket with paper.. or buy a new sensor
Panasonic... • Answered on Jul 14, 2010
its a receiving error code means a computer was trying to fax you and it didnt connect properly
if the machine is a panasonic .. press monitor .. you will see monitor on the machine display.. then press the volume down button .. then press stop when your done
1-- do you have a memory card in it.. if so please remove..
2--If 1 did not work unplug the machine then hold energy saver button down and plug it back in .. should ram initialize... if so use the up arrow and shipment set the machine " when you see shipment set hit start and 2 for no reseting counters..
3-- if step 2 did not work then you have a main board problem
There is a fix for this. But only a Panasonic tech has access to the parts for the fix. The toner sensor underneath must be moved closer to the cartridge, you are not low on toner.
Panasonic... • Answered on Jun 15, 2010
It means you had a power failure
press
function
71
set
enter date and military time
set
stop
Panasonic... • Answered on Jun 07, 2010
Press
Function
74
set
12
set
set
stop
Panasonic... • Answered on Apr 09, 2010
Unplug the machine from the rear
Hold down the ENERGY SAVER key
Plug back in while holding down the above key
Scroll down to SHIPMENT SET
press SET
press 2
Wait for the reboot
Panasonic... • Answered on Apr 07, 2010
Panasonic Panafax UF-790 Plain Paper Laser Fax Logo
73 questions posted
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Richard C Cohen
Richard C Cohen
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Office Equipment & Supplies
Most Popular Question
i have a panasonic uf 6000 stuck in self
  • Office Equipment & Supplies
