20 Most Recent
ION Audio Pure LP USB Conversion Turntable Questions & Answers
How do i stop the arm skipping on an ion pure turntable. This happens on old and new vinyl. the machine is just out the box.
To stop it jumping you need to increase the weight located on the end of the arm slightly then test play a record, if it jumps you increase the weight again slightly and test again. Repeat till it stops. If it rumbles decrease the weight.
As for the sound. You need to find out if the deck uses a magnetic cartridge or some other type. If it uses a magnetic cartridge it will have to be connected to an amp with a Magnetic Cartridge Pre-amp built in. Or you will need to purchase one (pre-amp that is) if it has not got one. This can be then be plugged into a standard jack socket.
If it does not use a magnetic cartridge, don't put it one marked for "phono". Instead put it in a tape, aux or cd socket.
My turntable appears to be uneven. it looks like a rolling hill when spinning, can this be fixed
Is it just the matt that records sit on that's the problem or the whole platter?
If it is the matt you can peel it off and get a new one from somewhere such as as Amazon. It doesn't have to be the same brand as the turntable as long as it fits on.
Just search for "turntable matt".
If the platter is the problem it might be caused if the platter is plastic by either a chemical or heat warping the platter. Has it been exposed to the sun for example? Some chemicals such as oil and polish can cause it to bend out of shape.
It's likely if the platter has warped that it will need to be replaced.
Rumbles badly, unable to play.
Adjust the weight on the end of the arm, till the rumble sounds stops, but the stylus stays in the groove. It's trial and error doing this I'm afraid.
I have connected my Akai AP A510 turntable to my
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn
