20 Most Recent Transcend 128GB SDXC Memory Card Questions & Answers
Usb unknown device
you can use driver booster
8/29/2022 3:05:02 PM • Transcend... • Answered on Aug 29, 2022
3answers
Free online virus scan
You can use Eset online Scanner Free Virus Scan Online Virus Scanner from ESET
3/15/2022 4:07:05 PM • Transcend... • Answered on Mar 15, 2022
D33193 USB drive. How can I remove write protect?
I don't believe you can
8/13/2021 8:04:51 PM • Transcend... • Answered on Aug 13, 2021
Computer will not detect my Transcend otg usb 3.0 dual flash drive
Put it also in another computer system to check it it is working. If the memory size is 64GB, you might need ex-fat formatting. This filesystem option must be available on your system's OS.
11/27/2016 2:43:03 PM • Transcend... • Answered on Nov 27, 2016
My transcend jf v33 / 32gb pendrive not support my system
it has to be supported, what OS is on your computer?
10/20/2015 2:00:02 PM • Transcend... • Answered on Oct 20, 2015
How do i unlock my sd mini 8gb card
On the side of the SD adapter is a small switch that makes it read only. Move the switch to the other position and see if that is the problem.
1/18/2015 8:19:37 PM • Transcend... • Answered on Jan 18, 2015
How to unhide hiddeen foldres
View this sites to show hidden files and to unhide them. http://www.wikihow.com/Unhide-Folders-in-Windows-7
8/13/2014 12:10:43 PM • Transcend... • Answered on Aug 13, 2014
USB MEMORY TRANSCEND
Insert it in a memory card reader connected to your computer and use the operating system to format the memory. If it is a card, to be used in a camera, also try to format ir in the camera you put it in.
8/2/2014 12:34:37 PM • Transcend... • Answered on Aug 02, 2014
Transcend 16gb pendrive note formating error & it is wright protected
u can format ur pendrive, boot ur system on safe mode step -1 restart ur system and press F8 then u will get some options choose safe mode without or with networking, when u successfully logged in safe mode insert ur memory card or pendrive in system u will able to format it. if problem still here are transcend service center details in bangalore Transcend Service Centre Bangalore Address Address : No:2 & 3, New Raja Building, 2nd Floor, Nr Road City : Bangalore Karnataka, India. Pincode : 560002.
Phone Number : 41129213, 41129213, 9740975091 Email-id : [email protected] Contact Person : Vigneshwari Website : http://in.transcend-info.com/
6/27/2014 5:57:13 PM • Transcend... • Answered on Jun 27, 2014
Usb device not recognized
You will need to format the drive to fat32 file system using software that should be available from the drive maker.
6/22/2014 8:29:49 AM • Transcend... • Answered on Jun 22, 2014
Led blink once, not detected
Need additional info. Has it always been this way or did it work at one point in time? Have you checked in Device Manager to insure the USB port(s) are in working order?
6/22/2014 7:48:24 AM • Transcend... • Answered on Jun 22, 2014
Customer care chennai
Please consult your documentation. Or visit the Transcend website for additional help and documentation.
6/22/2014 7:44:12 AM • Transcend... • Answered on Jun 22, 2014
Transcend usb 4 GB not format
Put your USB drive in your computer and open My Computer. Right-click the USB drive, and then select "Format" from the menu. I would select FAT32 for "File System" and set the "Volume label" to something you like (it'll be the name of the USB drive; enter up to 11 characters (letters and numbers without spaces). You may optionally use "Quick Format" or uncheck it to do a full format. After entering that information, click "Start" and the drive will be formatted. You'll the progress bar advance as it formats. When formatting is complete, you will be prompted.
4/30/2014 5:52:49 AM • Transcend... • Answered on Apr 30, 2014
Remove write protected usb 8gb
To disable the write protection:
    1.From the Start menu, click "Run", type "regedit", and press <Enter> or click <OK>. 2.Navigate to HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Control > StorageDevicePolicies. 3.Double click on "WriteProtect" and change the value to 0 (WriteProtect = 0 for disabled; 1 for enabled). 4.Close the registry editor and restart Windows. 5.After Windows starts, test writing to your USB drive. Important Note: Serious problems might occur if you modify the Windows registry incorrectly. **PLEASE** make sure that you follow these steps *exactly* and *carefully*. For added protection, back up the registry before you modify it in case you have trouble so it can be restored. For more information about how to back up and restore the registry, follow the steps as in the KB Article: http://support.microsoft.com/kb/322756/
4/30/2014 12:40:31 AM • Transcend... • Answered on Apr 30, 2014
Deleted files are coming back
If you restore files from your "Recycle Bin" they will be put back where they were deleted from. Could this be the case for you?
4/29/2014 5:53:35 PM • Transcend... • Answered on Apr 29, 2014
0answers
Volume label 4gb
Be the first to answer 1/20/2014 3:36:06 AM • Transcend... • Posted on Jan 20, 2014Be the first to answer
Transcend 128GB SDXC Memory Card Logo
0 questions posted
Top Transcend Electronics - Others Experts
NOEL
NOEL
Larry
August Brown
August Brown
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Transcend Electronics - Others
Most Popular Question
computer will not detect transcend otg
  • Electronics - Others
