20 Most Recent Dyson AM05 Hot Cool Fan Heater Questions & Answers
How do I change heat to cool?
Hi Annette, it's Jack at Dyson. When you lower your AM05's target temperature (shown on the LED display on the front of the machine) down to 0°, the red light around the on/off switch will turn blue. This shows your machine is now running in fan-only mode, without the heating elements - suitable for use in hot weather. You can then adjust the airflow power and oscillation to suit your needs. change-heat-cool-yb2iqq4t3gdfozzh4fdwdnjv-3-0.jpg I hope this helps. If you need any further advice, visit www.dyson.com and click 'Support'. Or if you'd like to speak directly with our experts, you can reach the Dyson Helpline on 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
3/9/2016 12:18:13 PM • Dyson AM05 Hot... • Answered on Mar 09, 2016
2answers
Why won't my fan oscillate?
There is a little arm attached to the motor that makes the fas oscillate. If it gets disconnected you will have that issue. Check the linkage.
3/1/2016 10:25:20 AM • Dyson AM05 Hot... • Answered on Mar 01, 2016
My am05 shut off with a E 5 Display
Hi William, it's Jack at Dyson. If your Dyson AM05 Hot + Cool heater displays an E5 error code, you should be able to reset this without difficulty. Just turn off the machine using either the remote or the control on the base, then unplug it for at least 30 seconds. Once you've done this, plug it back in and re-test. The issue should be resolved. I you continue to see the E5 error code after trying this please get in touch directly so we can provide further assistance. If we're not able to resolve the issue over the phone with some simple troubleshooting checks, we should be able to help under your 2-year Dyson warranty. You can reach our experts directly by calling us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
1/29/2015 9:36:32 AM • Dyson AM05 Hot... • Answered on Jan 29, 2015
How do you remove the base from the dyson am05
Hi there, it's Jack at Dyson. AM05's base is secured in place by a catch - you should see this if you look at the underside of the machine. You can open the catch at the same time as rotating the base to remove it. If you'd like one of our experts to talk you through this you're welcome to contact us directly. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU)
9/29/2014 3:13:54 PM • Dyson AM05 Hot... • Answered on Sep 29, 2014
H2 error code on Dyson hot/cold fan unit.
what is the question?
7/10/2021 10:18:43 AM • Dyson Dryers • Answered on Jul 10, 2021
Dyson Am04 model no longer turns on due to a power surge. What part is required to fix it? TIA.
First thing is to check the wall socket. Use a desk lamp or something similar and plug it into the socket you use for the heater. If the lamp works so does the socket. Next check the fuse. UK machine have a fuse in the plug, other countries use different systems. If all these check out OK the surge may have damaged a circuit board inside the heater. Only a Dyson specialist could help you with that.
8/17/2020 3:11:16 PM • Dyson Dryers • Answered on Aug 17, 2020
DYSON AM08 PEDESTAL FAN HAS OPERATED FLAWLESSLY FOR TWO YEARS ! TODAY I STARTED IT , IT RAN AS USUAL THEN QUIT AFTER A MINUTE. I TRIED AND SEARCHED FOR A CAUSE FOR AN HOUR FOUND NOTHING UNUSUAL. WHAT COULD BE WRONG?
Probably the bearings are dry. remove the fan and housing to get to the shaft and oil it. The circuit breaker is shutting it off because it is drawing excessive current.
9/24/2019 8:58:41 AM • Dyson Dryers • Answered on Sep 24, 2019
My dyson hot and cold fan is displaying code C2 and won't turn on or off
quote from amazon site***Mine also showed H2. I had a suspicion that it was the remote causing it. Changed the remote battery (CR 2032), turned on the heater and let it circulate for 3 minutes, then I went and tested all remote buttons. It worked! No more H2 error code! Amazon Customer · September 11, 2018
8/30/2019 6:28:22 AM • Dyson Dryers • Answered on Aug 30, 2019
How to detach Dyson Pedestal AM08 fan?
Call Dyson support, I do not have this answer and a search rendered no results
DYSON USA SUPPORT
Call us at 1-866-693-9766
8/2/2018 10:12:47 PM • Dyson Dryers • Answered on Aug 02, 2018
My dyson heater-fan shows a E8. What should I do?
7/5/2018 1:16:01 PM • Dyson Dryers • Answered on Jul 05, 2018
Dyson AM05 Hot Cool Fan Heater Logo
Popular Tags
7 questions posted
Top Dyson Dryers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
NOEL
NOEL
Are you a Dyson Dryer Expert? Answer questions, earn points and help others
View Most Popular
Dyson Dryers
  • Dyson Dryers
Most Popular Question
dyson am05 kept showing e7 code
  • Dryers
