20 Most Recent Cisco Linksys Wireless N Home Router WRT120N Wireless router (745883589319) Questions & Answers
Connect to http://192.168.1.1/
The default password is "admin". No username required. If you don't remember the correct password and you don't want to use some brute-force cracking software the only option is to reset the router pressing reset for 30 seconds. After that everything should be back to factory defaults including the default password.
If you need any kind of technical assistance you can contact support cell at here
Cisco Linksys... | Answered on Apr 21, 2017
so type in your password to access it
Cisco Linksys... | Answered on Jun 03, 2015
In the Administration area of the router, you have the option to do a Firmware Upgrade. Once there, you can browse to the firmware file you'd downloaded earlier. No need to use any program other than the smarts within the router itself. DON'T do anything while the router is upgrading firmware!
Cisco Linksys... | Answered on Jun 02, 2014
There's a Reset button on back or bottom. Press and hold until the power LED blinks, then release it and the login/password will return to their defaults.
That's probably an incompatibility issue between the iPad and printer. Router is most likely not to blame.
Cisco Linksys... | Answered on Jun 01, 2014
If you are able to access router settings then whats your problem..IP can vary ..that not an issue..are you getting any problem??
Cisco Linksys... | Answered on Jan 23, 2013
Hello from here you can download a manual:
http://homesupport.cisco.com/en-us/support/routers/E1000
You need to install Cisco Connect software.
To reset it you have to press a small button at the back of the router
With power on.
E1000 Default Password & Other Default Login Data Version Default Username Default Password Default IP Privileges All [none] admin 192.168.1.1 Administrator
Good luck
Cisco Linksys... | Answered on Oct 29, 2012
Login via web browser 192.168.1.1 User: (none / blank) Password: admin.
Cisco Linksys... | Answered on Oct 22, 2012
I can suggest you a solution. I am not sure whether it will work or not but you can try this and see if that works.
Open the setup page of Linksys router using 192.168.1.1.
On the setup page you will see Static DNS 1. Enter 4.2.2.2 in Static DNS1. And Enter 4.2.2.3 in static DNS 2 option. Save the settings.
See if this works.
Also make sure that firmware on your router is upgraded.
Cisco Linksys... | Answered on Jun 08, 2012
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Cisco Linksys... | Answered on Mar 04, 2012
If you know your way around computers and related devices go to http://www.dd-wrt.com/site/index and download the software for your device and install it. This is a much better solution than the stock firmware provided by linksys. !!!!!! WARNING !!!!! if you aren't comfortable installing it don't as you could brick your router. There are plenty of resources on the site to get it installed however.
Cisco Linksys... | Answered on Jul 03, 2011
Use an Ethernet cable to connect from the network-port on your computer to one of the LAN ports on the router.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
You should see output like:
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
if the router has self-configured, and is ready for "wired" usage.
Then, start Internet Explorer.
Type http://192.168.1.1
Press Enter
Login to the web-server "inside" the router
Click to run the "Wireless Networking Setup Wizard" to configure it for "wireless" usage.
Cisco Linksys... | Answered on Apr 01, 2011
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Cisco Linksys... | Answered on Mar 19, 2011
    these are the popular firewall for recent days:
    ·Packet filtering firewall
    ·Circuit-level gateway
    ·Stateful inspection firewall
    ·Application-level gateway (aka proxy firewall)
    ·Next-generation firewall
Cisco Computers... | Answered on May 28, 2020
  • Packet filtering - ...
  • Stateful filtering - ...
  • Routing support - ...
  • Transparent firewall - ...
  • AAA support - ...
  • VPN support - ...
  • Supports IPv6 - ...
  • VPN load Balancing -
Cisco Computers... | Answered on May 13, 2020
DO NOT CALL FAKE NUMBERS OR GO TO FAKE WEBSITES. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you. Please only ever use the support contacts from the official company website.
Cisco Computers... | Answered on Oct 21, 2019
Su mensaje no califica como una pregunta o consulta para un problema, intente en otro lugar
NO HAGA ESTE SITIO CON SU BASURA
Lleve su BASURA a otro lado
Su mensaje califica como SPAM
Cisco Computers... | Answered on Oct 20, 2019
Your message does not qualify as a question or query for a problem, try somewhere else
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
Cisco Computers... | Answered on Oct 19, 2019
Cisco Linksys Wireless N Home Router WRT120N Wireless router (745883589319) Logo
24 questions posted
Top Cisco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Jax Planet
Jax Planet
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Cisco Computers & Internet
Most Popular Question
tried connecting cisco linksys router
  • Computers & Internet
