20 Most Recent
Sharper Image Remote Cooking Oven Bbq Thermometer Mi212 Questions & Answers
I have an Mi212 remote
I had the same problem with mine. As soon as I replaced all 4 batteries, hit the reset button on the probe unit, turned both off, turned the receiver unit on, then turned the probe unit on, it started working fine.
Is "Halal" meat safe for humans?
Hi, Carole. According to the Wiki article on Halal, it is an Arabic word meaning "permissible," referring to food, objects or actions. With respect to food it is similar in intent to the Hebrew word, "Kosher." In both Islam and Judaism, for example, pork is not considered permissible. There is much more to know about Halal, but I'll defer to our Islamic neighbors to answer more fully. Short answer: entirely safe. Enjoy!
12/27/2023 4:43:31 AM •
Grilling
Answered
on Dec 27, 2023
How to take top grill off
You need to identify brand and model. Armed with that, someone may be able to assist you. Or, you can use google to search for a user manual if you include the brand and model in the search. What follows are general instructions for a lot of grills but may not fit your model:
Open the door(s) of the grill.
Look up at the bottom side of the grill.
Remove the grill screws going up into the bottom of the grill.
Tilt the grill forward at the top and release the springs from behind the grill.
Lift off the grill.
12/22/2023 4:51:21 PM •
Grilling
Answered
on Dec 22, 2023
I need Casio exilim v7 update 1.01 and 1.02
It is recommended to visit the official Casio website or contact Casio customer support for assistance with obtaining the firmware updates for your camera.
Typically, manufacturers make firmware updates available on their official websites under the support or downloads section. You can search for "Casio Exilim V7 firmware update" on a search engine to find the official Casio support page for your camera model. From there, you should be able to locate and download the firmware updates you need.
If you encounter any difficulties or are unable to find the firmware updates on the Casio website, I suggest reaching out to Casio customer support directly for further assistance. They will be able to provide you with the appropriate firmware updates and guide you through the process of updating your Casio Exilim V7 camera.
Please note that when performing firmware updates, it's essential to carefully follow the instructions provided by the manufacturer to avoid any potential issues or complications during the update process.
I hope this helps, and I wish you the best of luck in obtaining the firmware updates for your Casio Exilim V7 camera!
6/21/2023 2:43:05 AM •
Grilling
Answered
on Jun 21, 2023
Propane not getting to burners; how do i fix
James,
Try Reseting the Regulator.....
1. Turn off the gas at the propane tank.
2. Disconnect the hose from the propane tank.
3. Open the lid of your BBQ Grill.
4. Turn all the burner valves to high.
5. Wait for 2 minutes.
6. Turn off all the burner valves.
7. Connect the gas line back up to the propane tank.
8. Turn on the propane tank slowly.
9. Light the grill using the proper ignition sequence.
Best to you.
6/5/2023 6:27:06 PM •
Grilling
Answered
on Jun 05, 2023
Where near Van Nuys, CA can I buy a propane gas line with regulator to replace the one on my Grand Hall barbecue grill model 7060
Amazon, or Home Depot. They are a standard unit that fits any grill. Why are you replacing it? They don't wear out. Sometimes they will lock out and need resetting.
https://www.google.com/search?q=propane+gas+line+with+regulator
Or any of these
Bbq Store Van Nuys, Los Angeles, CA
Yelp
https://www.yelp.com > search > find_loc=Van+Nuys,...
Reviews on Bbq Store in Van Nuys, Los Angeles, CA - BBQ Store, Barbeques Galore, Fireside BBQ & Appliances, Burbank Fireplace & BBQ, Armand's Discount ...
BBQ Grills Van Nuys
Extreme Backyard Designs
https://extremebackyarddesigns.com > bbq-grills-van-...
BBQ Grills Van Nuys. We carry a huge selection of Outdoor BBQ Grills to fulfill your grilling wants & needs. At Extreme Backyard Designs we have a huge ...
The BBQ Grill Outlet ' BBQ Grills, Smokers & Outdoor Kitchens
https://bbqgrillsandislands.com
The BBQ Grill Outlet offers the best gas grills, BBQ smokers, outdoor kitchens, pizza ovens, fireplaces and more! Compare the best BBQ brands!
5/20/2023 1:11:40 AM •
Grilling
Answered
on May 20, 2023
I have Vermont Castings remote 82220A-2. It works fine with new batteries which it burns out within a day or two of installing them. How do I correct that?
If your Vermont Castings remote is burning through batteries quickly, there could be several reasons for this issue:
- Weak signal: If the remote is having trouble connecting to the receiver, it may require more power to send the signal. This can drain the batteries quickly. Try moving closer to the receiver or replacing the receiver's batteries.
- Short circuit: A short circuit in the remote can cause it to draw too much power and drain the batteries quickly. Check the remote for any signs of damage or wear and tear, and try replacing it if necessary.
- Battery type: Make sure you are using the correct type of battery for your remote. Using the wrong type of battery can cause it to drain quickly.
- Remote programming: If the remote is not properly programmed or is programmed for a different device, it may require more power to send signals. Check the remote's manual for instructions on how to properly program it for your device.
If none of these solutions work, it may be best to contact Vermont Castings customer support for further assistance or consider replacing the remote.
2/27/2023 5:08:39 AM •
Grilling
Answered
on Feb 27, 2023
