20 Most Recent Panasonic RR-US006 Handheld Digital Voice Recorder Questions & Answers
0answers
0answers
0answers
0answers
Faulty Usb cable so I cannot download my sessions
try cutting the cable head that goes into the voice recorder and buying any USB cable extention and attaching the colored wires then solder them lightly and wrap a tap around each one of the cables then wrap te bundle and try it. just be carefull not to add too much soldering and keep cable from touching each other.
1/7/2009 9:46:11 AM • Panasonic... • Answered on Jan 07, 2009
Unit suddenly not recognized by computer
uninstall driver then turn off the PC then unplug the power cord from power socket, short its legs then leave it unconnected for 5min, then reconnect it to power socket and turn on PC and install driver it should work :)
let me know if that helped !!!
12/29/2008 9:44:50 PM • Panasonic... • Answered on Dec 29, 2008
How to rebuild, step by step, CD Changer Mechanism for Panasonic SA-AK20?
The nearest you will get is the service manual. Dowmload the service manual and follow the dissasambly and reassambly instructions to the letter, otherwise it will not work correctly and the timing will be out. https://elektrotanya.com/panasonic_sa-ak20.pdf/download.html
4/1/2024 8:34:15 PM • Panasonic Audio... • Answered on Apr 01, 2024
I have a panasonic sa vk880 and it wont give sound outputs, when i click on subwoofer button or surrounded enhancer it says error, please help
Try disconnecting all of the speakers except the left and right main speakers. If it works, check the wiring at the back of each speaker to make sure there aren't any shorts between the terminals. Better yet, just inspect the terminals both at the audio unit and the backs of the speakers. Stray strands of wire reaching across to the other terminal or exposed wire on the other side are a common problem. If you have that all cleaned up and still have the error, you may have shorted transistors in the output amp of one of the channels, very likely the subwoofer. This may be caused by shorted speaker wiring, or the amp may have failed on its own. In either case, you would have to replace both of the output transistors for that channel (they may be built into a power amp module, in which case the module must be replaced). This requires soldering skill, and the knowledge to identify the transistors and check them with an ohmmeter. Most of the time, it's a basic job for any skilled electronic technician. (I did run into one model that would have required two days of disassembly labor just to get at the failed transistors - I told the customer that wasn't designed for service and he would be better off buying something different to replace it.)
2/24/2024 9:03:10 PM • Panasonic Audio... • Answered on Feb 24, 2024
Panasonic ra-6100 service manual
PFA manual 1707647107959-e2c4883d-d37d-4e0a-9b95-64f65c0d2dc1_1-undefined-undefined-2.jpg 1707647107959-e2c4883d-d37d-4e0a-9b95-64f65c0d2dc1_2-undefined-undefined-3.jpg 1707647107959-e2c4883d-d37d-4e0a-9b95-64f65c0d2dc1_3-undefined-undefined-4.jpg 1707647107959-e2c4883d-d37d-4e0a-9b95-64f65c0d2dc1_4-undefined-undefined-5.jpg 1707647107959-e2c4883d-d37d-4e0a-9b95-64f65c0d2dc1_5-undefined-undefined-6.jpg 1707647107959-e2c4883d-d37d-4e0a-9b95-64f65c0d2dc1_6-undefined-undefined-7.jpg 1707647107959-e2c4883d-d37d-4e0a-9b95-64f65c0d2dc1_7-undefined-undefined-8.jpg 1707647107959-e2c4883d-d37d-4e0a-9b95-64f65c0d2dc1_8-undefined-undefined-9.jpg
2/11/2024 10:27:54 AM • Panasonic Audio... • Answered on Feb 11, 2024
Panasonic SA AKX71 controller
Original CD Stereo System comes with remote control and that does not need to connect. Moreover, buttons and switches are also given for manual use. If you want to use universal remote control, please specify make and model.
12/11/2023 1:51:56 PM • Panasonic Audio... • Answered on Dec 11, 2023
I NEED HELP for a Panasonic SA-AKX710. How can I connect my control please?
Panasonic SC-AKX710 user manual (English - 104 pages)
Manuals.ca https://www.manuals.ca > hi-fi systems > Panasonic Manual Panasonic SC-AKX710. View the Panasonic SC-AKX710 manual for free or ask your question to other Panasonic SC-AKX710 owners.
Panasonic SC-AKX710 Operating Instructions Manual ...
ManualsLib https://www.manualslib.com > manual > Panasonic-Sc-... Panasonic SC-AKX710 Manual Online: Preparing Media. Disc 1 Press [x] on main unit to open the disc tray. Put in a disc with the label facing up. ..
12/10/2023 6:26:29 PM • Panasonic Audio... • Answered on Dec 10, 2023
Panasonic DVD CD and vidio CD made in 2002
If your Panasonic DVD/CD player is not reading CDs and is making a grinding noise, there could be several issues at play. Keep in mind that specific troubleshooting steps may vary based on the exact model of your DVD/CD player. However, here are some general suggestions:
  1. Cleaning the Optical Lens: Over time, the optical lens inside the DVD/CD player can accumulate dust and debris, leading to reading issues. You can try using a CD/DVD lens cleaning kit to clean the lens. Follow the instructions provided with the cleaning kit.
  2. Check the Disc: Ensure that the discs you are using are clean and free from scratches. Even new CDs can have manufacturing defects. Try using different CDs to see if the issue persists.
  3. Inspect the Loading Mechanism: The grinding noise you're hearing could be related to a problem with the loading mechanism. Open the disc tray and visually inspect for any obstructions or foreign objects that may be hindering the movement of the tray.
  4. Reset the Player: Turn off the DVD/CD player and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This can sometimes resolve temporary issues.
  5. Firmware Update: Check if there are any firmware updates available for your DVD/CD player. Visit the Panasonic website, enter your model number, and look for firmware updates and instructions on how to perform them.
  6. Professional Inspection: If the issue persists after trying the above steps, it may be necessary to seek professional assistance. There could be a mechanical problem with the internal components of the player that requires specialized attention.
If you are unable to find the exact manual for your specific model online, you may want to contact Panasonic customer support directly. They can provide you with model-specific advice and may have access to manuals or troubleshooting guides for your particular DVD/CD player.
11/19/2023 8:55:07 PM • Panasonic Audio... • Answered on Nov 19, 2023
Is the Panasonic SA-AK750 basically the same as the SC-AK750?
The versus Google query is useful https://www.google.com/search?q=Panasonic+SA-AK750+vs+Panasonic+SC-AK750 which leads to https://www.kleinanzeigen.de/s-anzeige/panasonic-sa-ak750-hi-fi-stereo-tape-usb-5x-cd/2580715678-172-2463 and https://www.bhphotovideo.com/c/product/487963-REG/Panasonic_SC_K750_SC_AK750_660W_5_CD.html And the manual explains they are the system and the main unit System (model name) SC-AK750 Main unit (designation) SA-AK750 Front speakers SB-AK750 Subwoofer SB-WAK750 Here is the manual
Panasonic SC-AK750 Operating Instructions Manual
ManualsLib https://www.manualslib.com > manual > Panasonic-Sc-... View and Download Panasonic SC-AK750 operating instructions manual online. Philips CD Stereo System Operating Instructions. SC-AK750 stereo system pdf ...
CD Stereo System
Panasonic https://www.panasonic.ca > ALL > rqtv0200-p These operating instructions are applicable to the following system. System. SC-AK750. Main unit. SA-AK750. Front speakers. SB-AK750. Here is the remote control for it. https://www.google.com/search?q=panasonic+sa-ak750+replacement+remote+control ..
11/13/2023 6:27:31 PM • Panasonic Audio... • Answered on Nov 13, 2023
2answers
I have a panasonic SDR-S15and it has stopped transferring video to my PC. It transfers still pictures but not video.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjJvqOWw5SCAxX8jIkEHY63DB4QFnoECBwQAQ&url=https%3A%2F%2Fwww.dpreview.com%2Fforums%2Fthread%2F4197939&usg=AOvVaw34btXWSSWlq0eA4wpAk5o1&opi=89978449
10/26/2023 11:48:27 PM • Panasonic Audio... • Answered on Oct 26, 2023
SC-HC35DB DAB RADIO HAS STOPPED WORKING , ALL OTHER PARTS FINE ,
You need to tunr the power off at the wall socket. Leave the unit off for at least 5mins. Then whilst holding the power on button on the unit down, turn the power back on at the socket, keep the power button depressed for at least 5secs. When you release it you should see -----------------, in the display. The unit has just been reset to factory mode. All features should now be present again. Hope this helps.
10/16/2023 9:27:32 PM • Panasonic Audio... • Answered on Oct 16, 2023
Panasonic SA-HT75 Audio works for a few minutes, then stops.
Did you try self diagnostics ? The procedure for self diagnostic is given on page 29 of service manual Free Audio Service Manuals - Free download panasonic sa ht 75 g service manual
9/20/2023 11:29:49 AM • Panasonic Audio... • Answered on Sep 20, 2023
Panasonic RR-US006 Handheld Digital Voice Recorder Logo
Popular Tags
9 questions posted
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Audio Players & Recorders
Most Popular Question
faulty usb cable cannot download
  • Audio Players & Recorders
