20 Most Recent Sony VPL CS1 Multimedia Projector Questions & Answers
Horizontal Green Lines!
Hi Tim
I've seen this many times. Only way to get rid of it is to replace the Mainboard.
This will get worse as time goes by.
8/5/2022 9:21:38 PM • Sony VPL CS1... • Answered on Aug 05, 2022
4answers
Lamp/cover light blinking
Myn is a Sony 3LCD and it has just let me and game funs down ;Imagine Chelsea Vs Man U and this gadget projector won't turn on,th hall is full and my oh, the lamp cover buttorn fflashng and no light,, a zbiig let ddown
4/18/2015 4:45:01 PM • Sony VPL CS1... • Answered on Apr 18, 2015
Turns off fan blinks yellow
Check and replace the fan. Check the fan regulator electronic circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/
6/14/2014 5:41:33 AM • Sony VPL CS1... • Answered on Jun 14, 2014
Shuts off fan blinks yellow
It sounds like your bulb has expired and needs to be replaced. Here's a link to a free manual which explains how to replace bulb. http://pdf.crse.com/manuals/4074278111.pdf
6/10/2014 10:46:24 AM • Sony VPL CS1... • Answered on Jun 10, 2014
THE DISPLAY NOT CLEAR, HOW TO DO IT
display 1by 1 inch lineing
11/27/2013 11:11:13 AM • Sony VPL CS1... • Answered on Nov 27, 2013
Bleeding blue color upon projection
Yes you can replace the lamp, but service in must including the RGB Panels for the same. that will solve ur problem.
Viren
7/15/2013 5:33:11 PM • Sony VPL CS1... • Answered on Jul 15, 2013
What could be the issue if my projector turns itself off after only running for 1-2 minutes?
It maybe a problem with your lamp as they can run for a short while then shut down.When it shuts down do you get the lamp or temp indicator coming on?
2/1/2013 3:10:13 PM • Sony VPL CS1... • Answered on Feb 01, 2013
When i turn it on the black screen comes up and
change resolution down on the source (1024x768 should work)
3/9/2011 8:14:19 PM • Sony VPL CS1... • Answered on Mar 09, 2011
My Sony VPL CS1 projector was working on Monday
hi,
check the lamp cover is it open or not. there is switch for sensing, is the lamp cover is open or not. may be it became faulty. also check the lamp is it burned or not . if found burned replace it.
ok
12/22/2010 7:13:40 PM • Sony VPL CS1... • Answered on Dec 22, 2010
When the projector warms up
It is possible that your projector has the syncronisation fault in the video processor section. There is a possiblity that the chip is faulty or the corresponding allied cirrcuits have sprung up with some passive component weakness. What you can do is to open the set and warm up the areas near the main chip . Switch on the projector and if you notice the roll had stopped try do it to specific components and finally to the main IC .Replace when you are confirmed but attempt only if you are experienced or seek help to replace. Hope this helps. Good day
8/10/2010 10:36:07 AM • Sony VPL CS1... • Answered on Aug 10, 2010
Sony svga vpl cs1 projector horizontal roll
first of all open the projector and clean it form a bursh then cheack a losing if stips and jumpers thats it
4/24/2010 8:39:50 PM • Sony VPL CS1... • Answered on Apr 24, 2010
Sony VPL-CS1 projector
Hi there
You should first check if there is any visible damage on your lamp. If not then it could be a faulty Ballast ( lamp powersupply )
2/5/2009 3:59:38 PM • Sony VPL CS1... • Answered on Feb 05, 2009
2answers
Projector SONY VPLCS!
I had the same problem with a Sony VPL CS1. It's not the mainboard, but the blue filter - cost to repair runs around $500 US.
Hope that helps.
1/6/2009 2:10:35 AM • Sony VPL CS1... • Answered on Jan 06, 2009
Have you replaced its Lamp?
10/27/2008 5:06:42 PM • Sony VPL CS1... • Answered on Oct 27, 2008
No image when Windows loads up, image OK before the windows starts
Hi there
Check that your resolution on your PC matches that of your Projector.
i.e : If your Projector is XGA ( 1024x768 ) that should be the resolution of your PC as well.
To change your resolution on your PC simply right click on your desktop and go to properties and then settings. You'll see the resolution bar in the middle.
3/26/2008 12:59:41 PM • Sony VPL CS1... • Answered on Mar 26, 2008
Purple and green and shaking....
Hi guys
You will have to replace the LCD's .
Must warn you that it is very expensive
3/26/2008 12:56:37 PM • Sony VPL CS1... • Answered on Mar 26, 2008
Sony VPL CS1 Multimedia Projector Logo
27 questions posted
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
AAA TV Service
AAA TV Service
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Office Equipment & Supplies
Most Popular Question
lamp cover light blinking
  • Office Equipment & Supplies
