20 Most Recent Toshiba MD20FP3 Combo Questions & Answers
manual
Accessing TV Menu withough original remote
No you need the remote ! and even most universals will not do that function for you either!
You can order an orignal replacment remote from www.remotes.com and that will let you access all of the tvs functions!
I hope I was of big help!
Please rate my FREE response!
Thank You!
3/22/2009 7:11:37 PM • Toshiba MD20FP3... • Answered on Mar 22, 2009
2answers
Toshiba MD20FP3 radomly turns off
a loose contact on the mainboard, if you know how to solder then have patience in soldering what you can see in the mainboard that may be having loose contact.
10/9/2008 1:37:22 AM • Toshiba MD20FP3... • Answered on Oct 09, 2008
2answers
Toshiba MD20FP3 not turning on
Is a good thing the main fuse is not open,your problem is in the power supply ,as I understand you have no indication of power(no lights,No clicks)The 5 volts that power the microprocessor might be missing,this 5 volts usually come from a regulator,this regulator should have 12 volts in one side and the 5 volts in the other,the 12 volts come from the secondary of a transformer and it has its own fusible resistor,if the resistor is open is because the regulator is shorted and it need to be replaced.This is a good place to check.Be careful when checking this parts.If you are not too familiar with tv service seek the assistance of a servicer,it should not be too expensive.
1/15/2007 9:21:32 PM • Toshiba MD20FP3... • Answered on Jan 15, 2007
Toshiba MD20FP3 Combo does not turn on. Help!
Not unless you have taken the time to learn all the safety issues concerning the HI voltage safety facts, in the repair of electronics? It sounds like your tv has a problem in the sweep/power supply circuits, and since these sets have NO user serviceable parts< its best too leave these types of repairs to a certified electronic technician. Good Luck
6/25/2006 9:41:30 AM • Toshiba MD20FP3... • Answered on Jun 25, 2006
2answers
How come my 10-year-old toshiba tv now goes to screensaver in the middle of a program I'm watching
Hi, Please factory reset your toshiba tv or update your tv settings so that the screensaver is disabled. Either of these 2 actions should help you overcome this issue. If you don't see a screensaver option on your remote, please reference the table of contents within your manual. Thank you.
11/5/2022 4:23:48 AM • Toshiba... • Answered on Nov 05, 2022
2answers
Toshiba 49L420U does not turn on
The 5 and 3.3 voltage is standby and that would be good if you get a standby light, you won't see the 16 volt unless the power supply is at full power or out of sleep mode. Look at the legend on the power board connector going to the main for something like PWR_ON, it may be marked different, but will have something about power on, you need to see just over 3 volts there when you push the power button, if 3 volts is there replace the power supply, if you don't see that go to the connector coming from the inferred board on the main board, measure the voltage at the pins, one will be 5 volts and one of the others need to change voltage when you push the power button on the remote, measure these one at a time, if none chance replace that board, if you see a change in voltage on one of the pins replace the main board.
9/14/2022 12:03:24 AM • Toshiba... • Answered on Sep 14, 2022
Toshiba TV Stuck in Standby
Are the lines always vertical or horizontal? Are they black or multiple colors?
9/5/2022 9:12:01 PM • Toshiba... • Answered on Sep 05, 2022
Hisense tv struck by lightning repair kid
Total right off unfortunately. 125,000 volts is very damaging to all the components. Claim on house insurance, some cover it.
9/5/2022 8:40:01 PM • Toshiba... • Answered on Sep 05, 2022
2answers
Trouble with Toshiba flat screen
Over time with heating and cooling of the power board the fuse holder loses tension and won't make proper contact with the fuse, remove the fuse and bend the contacts together and see if it works, if it still gives trouble replace the power supply or solder the fuse to the holder if you have a soldering iron and can do the repairs.
8/19/2022 9:59:07 PM • Toshiba... • Answered on Aug 19, 2022
2answers
Same problem, my Toshiba 26AV502R not powering on. I found the ceramic fuse blown on the power board & replaced it. The new fuse blew the instant I plugged the TV in. Any idea what is causing this?
Replace the power board if you can find one, unless you're an electrical engineer with the proper test gear high speed switching power supplies are to complex to service
8/19/2022 5:10:17 AM • Toshiba... • Answered on Aug 19, 2022
I have a Toshiba W255 VCR hooked up to a Kinivo HDMI switch via an hdmi converter to an older Panasonic plasma TV.
try a converter box that allows multiple devices
8/19/2022 4:53:45 AM • Toshiba... • Answered on Aug 19, 2022
Internet on my old Toshiba RV75
Probably you need a digibox between your internet connection and the old TV.
8/14/2022 6:47:54 PM • Toshiba... • Answered on Aug 14, 2022
I have a Toshiba dvr620 and can't remember which buttons to push to activate the sound.
What TV or monitor is your DVR620 connected to? There is an Audio button on the original DVR620 remote (not a universal remote), it's just above the TOP menu (displays the Title List for the current video). This lets you access a DVD audio menu or change a VHS playback between Hi-Fi or mono audio out. All other volume changes will be controlled by the controls for your TV or sound system. (This will depend on which video/audio out you have connected. Optical and some RCA audio output choices will be connected to an amplifier or home theater speaker system. If you are using HDMI or component/composite cables to a TV, then the TV speakers are probably active.) The manual for the Toshiba DVR620 is available at Crutchfield on the product page: https://www.crutchfield.com/S-Qjp9jnoviHC/p_052DVR620/Toshiba-DVR620.html . Look under the What's in the box header on the right side of the page. The current link to the manual is https://pdf.crutchfieldonline.com/ImageBank/v20101107082900/Manuals/052/052DVR620.PDF . I hope this helps. Cindy Wells (If you have the DVD recorder connected to a monitor that doesn't have speakers, connect one of the audio out options to a sound bar or other audio equipment.)
8/8/2022 10:43:30 PM • Toshiba... • Answered on Aug 08, 2022
The hdmi ports are 'hidden' in the input menu of my old Toshiba tv. Is there a way to unhide them? I don't have a remote.
Everyone needs a remote made for the television they are using. Have a read of this Tip I wrote. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
8/5/2022 3:10:29 AM • Toshiba... • Answered on Aug 05, 2022
Toshiba MD20FP3 Combo Logo
5 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
toshiba md20fp3 not turning
  • Televison & Video
