20 Most Recent Sony Xperia Z1 4G LTE" Questions & Answers
Hi Anonymous. The link below is a short YouTube video showing how to rest the pattern code on your phone, The guy shows 3 ways but the 3rd way is a factory reset meaning you loose everything in your phone but the first two ways are worth watching. Also there's videos down the right side of the link that might help as well.I hope this helps...... CHEERS..
EASY WAYS How To Unlock Android Passwords
Sony Xperia Z1... | Answered on Apr 29, 2016
Tip
How to Take a Screenshot on Sony Xperia Z1
1) Go to the display or the screen in your Sony Xperia Z1 which you want to capture.
2) Take a screenshot. Press the Volume Down button on the side and the Power button for about 2-3 seconds. Make sure that both the buttons are pressed TOGETHER, otherwise it won't work.
3) View your screenshot. You will immediately hear a clicking sound, confirming that the screenshot has been taken. You may also see the text "Saving your screenshot" on your phone's display during the process.
To view your screenshot, click on the screenshot notification in the notification tray or simply go to your Photo Albums and you will find the screenshots in a folder named "Screenshots."
on Jan 10, 2015 | Sony Xperia Z1 4G LTE"
Make sure that the phone's WiFi feature is switched on. Check the WiFi settings to make sure that the phone is picking up your WiFi router. If required, re-enter the WiFi password.
Sony Xperia Z1... | Answered on Sep 17, 2014
Please put this question on the Amazon site. Open the account you uses to order this phone. Or check the support part of the site.
Sony Xperia Z1... | Answered on Aug 06, 2014
1 does it have bluetooth
2 is it turned on
3 have u searched for devices i.e. in settings -- music -- play over bluetooth -- select device i.e. Portable Sound System Device / Click / Ok / Play?
Sony Xperia Z1... | Answered on Mar 17, 2014
Unfortunately this is a Japanese spec walkman and there is no option to change the language!
you could try to flash (replace) the firmware from an English spec walkman but if not done properly that could damage it and make it unusable!
I would just live with it and possibly learn Japanese ??
Sony Cameras | Answered on Jun 09, 2020
You have to format SD cards in the camera they are installed in. The operating systems are proprietary to each make, and sometimes even a specific model. Read this
http://www.peachpit.com/articles/article.aspx?p=2022659&seqNum=4
SONY NEX F3 "writing to memory card unable to operate" please help ...
https://www.dpreview.com > ... > Sony Alpha / NEX E-mount (APS-C) Talk
Jul 8, 2013 - 6 posts
there is a problem with my sony nex f3, when im taking a picture and then ... the card in a computer, format it, insert it in the camera and format it ... WHERE IS FORMAT SD CARD LOCATED: Sony Alpha ...
Mar. 27, 2017
REINSERT THE MEMORY CARD: Sony Alpha / NEX E ...
Mar. 9, 2016
Sony A7 : Unable to read memory card. Reinsert Memory ...
Jul. 17, 2017
memory card error?: Sony Alpha / NEX E-mount (APS ...
Aug. 19, 2010
More results from www.dpreview.com
Formatting Your Memory Card ' Getting Started with Your ...
www.peachpit.com > articles > article
Feb 27, 2013 - Jerod Foster covers a few things you need to know before firing up your Sony NEX-6, including choosing and formatting your memory card, ...
Sony Cameras | Answered on May 25, 2020
Not unless your willing to do it yourself.
Tweezers to pick at it or a precision screwdriver set to dissemble the unit and remove the card and reassemble.
Good Luck
Mr.Mike
Sony Cameras | Answered on May 21, 2020
clean memory slot (use air blower contact cleaner spray etc carefully and less force lest the dust particles will fall on the CCD.
Sony Cameras | Answered on Jan 08, 2020
lens section motor may struck
Sony Cameras | Answered on Dec 07, 2019
Sony Xperia Z1 4G LTE" Logo
9 questions posted
Top Sony Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Harrie
NOEL
NOEL
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
forgot screen lock pin
  • Cameras
