20 Most Recent TwinMOS Technologies MP3 USB S21 256 Mb key 256 Mb MP3 Player Questions & Answers
To be honest I think your memory card has had its day and I could only suggest that you buy a genuine memory card from a trusted seller ie a local camera store or a large supermarket.
I know that the above seams harsh but I too have struggled with cheap sd cards when an a more expensive one will give far more service.
TwinMOS... • Answered on Apr 27, 2017
You have to thow it away. Sorry. But the storage on your MP3 player is corrupt. This happens alot with USB devices.. Specially Thumbrives and mp3 players.
TwinMOS... • Answered on Jan 25, 2008
No. Your Amazon library is a list to music that is already on Amazon, in other words, a list of shortcuts. You can store MP3 music you own on your computer if you buy an Apple Music Anywhere License.
Audio Players &... • Answered 3 hours ago
HI. I also have the same system..but it is in English .version .do you want me to send it to you.3_26_2012_7_30_45_am.jpg
Audio Players &... • Answered 3 days ago
https://www.google.com/search?q=reset+time+on+Acctim+Model+13277X+alarm+clock&oq=reset+time+on+Acctim+Model+13277X+alarm+clock&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
Audio Players &... • Answered on Mar 28, 2021
i will scan my copy if you like
By looking at it it looks pretty old, I would say either that could e a protection mode signal or it could just be use and abuse and I might need to get a new one. Check your connections for pinched or touching wires and make sure you are not drawing to much current from where you have it plugged in at
First, check the ground connection for the body of the vehicle. If it's bad, the radio may not have enough power supply voltage for proper operation under load. Next, remove the front panel (see owner's manual) and check both it and the main unit for dirty connections. Another possibility is a fault in one of the output amplifiers is causing the shutdown. Usually, a problem here blows a fuse, and the entire unit does not work at all, but once in a while the shorted transistor or its complementary mate blows up instead of creating a full short and popping the fuse. In either case, both transistors on that output should be replaced (some designs use a sealed amplifier module with the transistors inside, in which case the module should be replaced). Figuring out which of the four amplifiers is bad requires checking the resistance of the output to both power and ground connections (done with the unit unplugged).
Do you mean the Philips AZ1040 portable radio with cassette player? If so, the volume control is the ring to the left of the LCD display. Turn the ring clockwise to increase the volume and counter-clockwise to lower the volume. The manual for this radio is available on the product support site: https://www.usa.philips.com/c-p/AZ1040_17/- . The current link to the manual is https://www.download.p4c.philips.com/files/a/az1040_17/az1040_17_dfu_aen.pdf . See page 10 for the volume control information. The button in front of the power slider on the top of the radio lets you turn on or off the dynamic bass boost. I hope this helps. Cindy Wells
Audio Players &... • Answered on Mar 27, 2021
Google the number on the top of it, or contact Panasonic direct, or take it to a Panasonic Service Centre. We don't sell parts. https://www.google.com/search?q=panasonic+sa-ht+340 ..
check with the manufacturer's website
Your best bet is EBAY... OR, locally, search for "Electronics Repair" and call the shops. They may have one lying around.
Audio Players &... • Answered on Mar 26, 2021
TwinMOS Technologies MP3 USB S21 256 Mb key 256 Mb MP3 Player Logo
4 questions posted
Popular Products
Top TwinMOS Technologies Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a TwinMOS Technologies Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • TwinMOS Technologies Audio Players & Recorders
Most Popular Question
error memory card
  • Audio Players & Recorders
