20 Most Recent Paradyne BitStorm 2600 (2611-a1-430) Questions & Answers
for obvious security reasons there is no way to recover the password with out completely wiping out the programming and starting from scratch.
Paradyne... | Answered on Apr 20, 2014
On bridge mode, DSLAM and modem are transparent to IPv6.
On routing mode, IPv6 is not supported yet.
Pls correct me if im wrong, tq
Paradyne... | Answered on Feb 19, 2013
Tip
Price of bitstorm 2600 ip dslam
hi there,<br />is there anyone can let me the price for this paradyne bitstorm 2600 ip dslam ?<br />thank you so much !<br /><br />
on Mar 30, 2011 | Paradyne BitStorm 2600...
you need a reboot and a serial console I'm afraid. Lots of places on Cisco that detail the password recovery process, it's quite complex so I'm not going to go into detail, but you need to be physically in the same room connected with a serial console cable (9600 baud) for it to work. Basically, use break to interrupt the startup, change the config register to ignore startup config, reboot , go to enable mode, copy run start, enter config mode and reset the password.
Paradyne... | Answered on Mar 26, 2010
192.168.1.1, subnet mask 255.255.255.0
The owner's manual is available online.
6218 A1 ADSL WIRELESS MODEM ROUTER User Manual paradyne Manual for EMI...
Paradyne... | Answered on Sep 27, 2018
Not exactly sure what you are saying.
When you turn on your UPS it blows the main fuse? Obviously you have a short. If you just changed the batteries I would go back and check that you have the positive and negative cables are connected correctly and there is nothing pinching the cables or touching the terminals.
If you didn't recently change the batteries and this might be a result of lightening, I would change the fuse and see what happens. If it continues to blow, toss it and get a new one. Could be the circuit board is bad but most likely the transformer is shorted. Unless you are a trained electronics technician you should not go any farther.
Paradyne... | Answered on Jul 22, 2016
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default. Change to anotherchannel.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedropouts and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
Paradyne... | Answered on Jun 30, 2012
Paradyne BitStorm 2600 (2611-a1-430) Logo
7 questions posted
Top Paradyne Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Paradyne Computers & Internet
Most Popular Question
need know
  • Computers & Internet
