20 Most Recent Sony BM-147 Desktop Cassette Transcriber / Recorder Questions & Answers
1. Try to change the tape speed on your machine. Sometimes that will fix it.
2. Maybe the tape is just old (has been dictated on too many times) and in that case, have the person dictate on new tapes and discard the old ones. They dont last forever.
Hope I could help!
Sony BM-147... | Answered on Dec 04, 2011
Hello on a BM-147 there is only one adjustment responsible for auto back space when you used foot pedal and that adjustment is next to the Display is call Reverse Time that controls the reverse function when you take foot control off from play but if the problem is when you take the foot off on REW and unit keeps going you have a bad foot pedal you can get a replacement at http://www.tvps.com/Products/ECS-Sony-IN-75-Heavy-Duty-Foot-Pedal---Pre-Owned__ECS-PIN-75.aspx
Sony BM-147... | Answered on Oct 10, 2011
The unit will need service. The reel that is on the right is pulling the tape to hard. There is a clutch system that needs service.
No, this unit does not have an erase feature. You would need a magnetict tape eraser such as a BE10.
Sony BM-147... | Answered on Jul 31, 2011
Hello your unit is the best 4 track transcriber on the market I recomend to sen it to repair. Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Sony BM-147... | Answered on Mar 12, 2011
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
My name is Bruce
Sony BM-147... | Answered on Jan 16, 2011
Hello you can get one at http://www.tvps.com/Products/SONY-BM-147-Four-Track-Transcriber---Pre-Owned-BM147__SO-P-BM-147.aspx also you can send your unit to have repair to Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem Good Luck
Sony BM-147... | Answered on Nov 26, 2010
Hello this unit has two speed switches one is located at the front of the unit next to Rew button make sure is set at 2.4 and the second speed switch is located at the bottom front of the unit VSC you can turn it on by pushing in and adjust the speed to adjust the right speed by using the first slide bar going from left to right if this is not helping you send your unit to service at Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Sony BM-147... | Answered on Oct 09, 2010
Hello the reason is your BM-146 it needs fix I now is a Older model but you can try this place they have parts for it, Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Sony BM-147... | Answered on Jan 07, 2010
Hello the SONY BM-147 Does Not have that Letter or secretary function to me is probably the you are using the original SONY FS-75 pedal and is really common the when the pedal brakes it goes to all the way to beginning you can try to unplug the pedal when is rewinding if when you unplug the pedal the unit stop you need to Buy a new Pedal you can find one at http://www.tvps.com/Products/ECS-Sony-IN-75-Heavy-Duty-Foot-Pedal---Pre-Owned__ECS-PIN-75.aspx or go to their site www.tvps.com for more options
you probably have a broken pedal here is one in a great price
Or if you feel better to send unit to service try this.
Sony BM-147... | Answered on Dec 18, 2009
Hello on the right side of unit is a switch for transcribe make sure is on the on position you are going to see on Deck A only lines on display, put your tape on Deck B is the only side that transcribes if the pedal does not respond you probably have a broken pedal here is one in a great price
If there is no sound on a channel, and you know the recording is there, then you either have a bad head or a broken wire at the tape head.
Sony BM-147... | Answered on Dec 12, 2009
This is a common symptom when the belt and pinch roller wear out. They will both need replacement.
Sony BM-147... | Answered on Dec 01, 2008
Unplug the player from the wall, press power button on the player for about 10seconds and plug in power again.
Sony Audio... | Answered on Jul 26, 2020
Assuming you are using a cable to connect your cell phone to the speaker you could be overloading the input of the speaker when you turn the phone volume up very high. That would cause distortion that might damage the speaker so it shuts down or turns off.
Sony Audio... | Answered on Jul 25, 2020
FIXYA DOES NOT MAKE VIDEOS TRY WWW.YOUTUBE.COM
Sony Audio... | Answered on Jul 20, 2020
Sony BM-147 Desktop Cassette Transcriber / Recorder Logo
20 questions posted
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sony bm1 47
  • Audio Players & Recorders
