20 Most Recent Braun Series 7 790cc Pulsonic Electronic Shaver Questions & Answers
Have Braun Series 7 pulsonic shaver. Bought April
It appears that the battery needs to be replaced. shaveroutlet.com has the battery you need and installation video. They can also replace it for you Braun Lithium Ion Battery for Pulsonic and Series 7 Model Shavers Braun Series 7 Shaver Disassembly Tutorial Professional Battery Replacement for Most Models
1/29/2018 4:33:42 PM • Braun Series 7... • Answered on Jan 29, 2018
I have a braun 790
These cleaning/charging units are prone to going bad. There are no parts for them, so, you will need to replace it. You will find at shaveroutlet.com Braun Series 7 and Pulsonic Clean Charge Base
6/23/2017 2:43:36 PM • Braun Series 7... • Answered on Jun 23, 2017
2answers
Braun Series 7 790cc: Battery is fully charged.
Hi, My guess is that the battery needs to be replaced with a new one. After many uses the battery will not charge properly any more. (internal discharge) Replace ,Replace ,Replace.
1/18/2012 4:46:31 AM • Braun Series 7... • Answered on Jan 18, 2012
The base for my Braun 7 series won't charge the
Hi, also it could be the charger is bad replace it. There is nothing you can do with that. Good luck
12/21/2011 5:00:48 AM • Braun Series 7... • Answered on Dec 21, 2011
Braun dosent charge
Hi, Replace the battery it is faulty. After many charges the battery will not charge any more its called internal discharge Repace it and you are good to go.
12/21/2011 4:56:34 AM • Braun Series 7... • Answered on Dec 21, 2011
Braun 9095cc shaver - can't deactivate the travel lock
I have the same travel lock problem with my series 5000. Also, I am having a similar problem with my other braun, the easy clean braun 5000, though it may still be intermittently used. I suspect that the travel lock problem is a braun common defect. After my braun razors die out, I'm finished with braun razors.
8/16/2021 7:05:03 PM • Braun Health &... • Answered on Aug 16, 2021
4answers
Braun Clean and Renew not working
I took the file on a nail clipper and turned the impeller inside the unit. Remove the cleaning fluid from the unit. Turn the unit upside down, On the part that sticks into the large hole of the fluid reservoir you'll see the impeller. Just turn it it enough to dislodge any whiskers and try it again. Worked for me. Good luck
8/15/2021 3:52:08 PM • Braun Health &... • Answered on Aug 15, 2021
Series 9 shaver. How can I insert the cleaning solution into the base station?
Cleaning under running water / Switch on the shaver (cordless) and rinse the shaver head under hot running water until all residues have been removed. You may use liquid soap without abrasive substances. Rinse off all foam and let the shaver run for a few more seconds.
5/2/2021 10:53:59 AM • Braun Health &... • Answered on May 02, 2021
How to clean body groomer onn on braun 5524
Remove the head and cutter. Clean both with soap, hot water and an old toothbrush. Use the damp brush to clean the body head area. https://www.directshaverparts.com/en/1469-braun-5524 ..
3/20/2021 4:57:16 PM • Braun Health &... • Answered on Mar 20, 2021
How to re-attach the metal spring on a vintage Braun Electric Razor with Trimmer Model #5564?
I struggled with this for a while too till I found a diagram. Place the wire spring and the flat detente spring (all the way to the bottom of the slot) in as shown in this diagram. When the trimmer plate goes all the way in, the spring will snap into its correct final position. Lee trimmerspringinstallposition-wcjy5cljug2w44525vz1ol4j-1-0.png
3/13/2021 2:49:39 PM • Braun Health &... • Answered on Mar 13, 2021
Where to send my braun 7526 razor to have the batteries replaced
Shaver Outlet can repair it. See link below https://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
3/10/2021 2:28:41 PM • Braun Health &... • Answered on Mar 10, 2021
Braun S3 razor comes on and off by itself
tom chichester says defective switch
1/16/2021 12:32:08 PM • Braun Health &... • Answered on Jan 16, 2021
2answers
My Braun thermoscan 6023 ear
So a very simple fix is to just clean the corrosion from the battery terminals inside the thermometer. You'll need a Torx T9 screwdriver (Maplin, eBay, Amazon, maybe pound shops).
11/28/2020 11:39:43 AM • Braun Health &... • Answered on Nov 28, 2020
Braun KM32 repacement beater
fixya does not sell Braun parts. Try contacting Braun for a source.
11/24/2020 7:38:26 PM • Braun Health &... • Answered on Nov 24, 2020
Braun Series 7 790cc Pulsonic Electronic Shaver Logo
15 questions posted
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Joseph Hoffmann
reference30
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Braun Health & Beauty
Most Popular Question
braun dosent charge
  • Health & Beauty
