20 Most Recent Interlogix GE SAW Wireless Indoor PIR Motion Detector Questions & Answers
Why is the LED light completely off after the walk test and lockout time?
Yes, it works normally. Things have evolved in the technology of security systems and now it is standard to have any LED turned off on any motion detector (the LED's are now used for walk-testing only), the standard DSC and Honeywell wireless motions also do the same thing.
  • This is a normal function for your motion detector. It's also a great power saving function since most of the current draw on the batteries is when it's transmitting a detection signal so if you're home and moving around it will only transmit every few minutes instead of every second, saving on battery life significantly (up to 5 years on average) but after the 3-minute lockout the passive infrared scans continuously until it transmits another motion signal.
Reason: most burglaries are done by someone who has been there before, if they see the LED then they know the motion will catch them moving in that given spot, then they can "map-out" where it's safe to walk (where the LED doesn't light up) for when they plan to return for a robbery. You can also make this device "more sensitive" by moving the jumper pin position by the right side battery and having the back mounting plate mounted using the bottom screw presets so it faces slightly downward instead of straight forward. Helpful tip: Change the batteries every 4 years if you're using Alkaline (dead or not) since the detector was engineered "too energy efficient" and the batteries actually leak and corrode the interior PCB at about the 5-year point on about 15% of the detectors with factory original duracell batteries (from what I've experienced in field service).
5/5/2015 6:12:14 AM • Interlogix GE... • Answered on May 05, 2015
What are some common types of sensors and detectors used in security systems, and how do they function?
Nice question. Do you have a specific concern, or an area to protect? I am an expert by experience.
The Various Types of sensors used in the Security Alarm ...
ResearchGate https://www.researchgate.net > publication > 34047974... Apr 7, 2020 - Microwave sensor (2) Vibration Sensors: Vibration sensors are sensors that are used for displaying, measuring, and evaluating linear velocity, ... ..
4/13/2024 11:02:25 PM • Home Security • Answered on Apr 13, 2024
2answers
Why should you opt for wooden flooring to improve your interiors?
Wooden flooring is known for its elegant look. It creates a warm ambience inside your home. Hardwood floors are elements of d?cor themselves, which are available in many different types and colours. Its durability will ensure a good interior investment while providing aesthetics to your home.
4/1/2024 6:34:20 AM • Home Security • Answered on Apr 01, 2024
2answers
Have Model: SM-79. Serial# 7951889.Operating OK. Rust buildup lower left corner outer cover with woman picture and STEAMBATH letters under her picture. How should I address matter?
Like Steve stated. I would add to use a rust-converting primer (the type that converts surface rust into an invert primer, stopping all future rusting).
As this is only occurring in the left corner, I'd try to determine exactly where the water is coming from (that's causing the damage). I suppose it could be condensation if the unit is over ten years old, but it also possible that a connection slightly loose or worn.
3/23/2024 5:27:58 PM • Home Security • Answered on Mar 23, 2024
Contact phone number for paragon lock and safe company
(972) 288-7557 · (972) 222-0646 Email is better to make contact.
3/22/2024 8:47:59 PM • Home Security • Answered on Mar 22, 2024
Mibao P450 Security Camera. I need a manual for it please?
Question edited for clarity. Here is the manual Jules https://www.manualslib.com/products/Mibao-P450-12979047.html And set up videos ..
2/23/2024 8:29:39 PM • Home Security • Answered on Feb 23, 2024
Soliom Camera Night Issues- Soliom Troubleshooting?
Top 10 Troubleshooting Methods to Fix "Your Security ...
https://soliom.net > blogs > tips > top-10-troubleshootin...
Aug. 22, 2019 - Night vision doesn't work, can't record anything, or infrared is not working. Can't connect to NVR security camera on my iPhone/iPad. 24/7 ...
Soliom Troubleshooting Support Provides Instant Resolutions!
https://soliom-support.com > soliom-troubleshooting
If the Soliom camera does not work properly To Illustrate, as the lights are not on in dark at nights, it is likely a cable problem, and it will cause no video and no image recording at night. You can use another cable to connect the camera to see if the problem is solved.
2/22/2024 12:52:03 PM • Home Security • Answered on Feb 22, 2024
SANNCE DN81BR 8-Channel 1080P Hybrid Security DVR. Need password reset. How to reset the password?
Question edited for clarity. Delete surplus words and fix the rest. From the manual on Page 24 7. Forget password Solutions: Method 1: Please use password resetting email to get password. Method 2: Please contact technical engineer to reset password. Or just buy another one
SANNCE 5MP Lite 8 Channel Security Camera DVR, H. ...
Amazon https://www.amazon.com > ... [Powerful 5-in-1 DVR & 5MP HD Stream]-- The hybrid digital video recorder works with up to 5MP TVI, AHD, CVI, CVBS analog and up to 2MP IP security cameras. · [H ... Rating: 3.8 · ‎ 331 reviews · ‎ US$69.99 · ‎ In stock Or ask them direct
Sannce Home - DVR User Manual.pdf
SANNCE https://support.sannce.com > en-us > articles > 900000... May 12, 2021 - Sannce Home - DVR User Manual.pdf. Support Team. 3 years ago; Updated. Follow. Apply to: DN81BG ...
2/21/2024 12:12:43 AM • Home Security • Answered on Feb 21, 2024
2answers
Qihan dvr super password
Te la 1.Te la encriptaran
2/14/2024 12:11:34 PM • Home Security • Answered on Feb 14, 2024
Paragon safe replacement keys
Key Replacement
Team Customer Service https://teamcustomerservice.com > key Replacement Keys are $35. This includes the key and all shipping and handling costs. Use the form below to request and pay for a key replacement. If we are ... ..
2/10/2024 5:36:29 AM • Home Security • Answered on Feb 10, 2024
My doorbell has gone quiet
It may have this silent option in either choice for volume or melody. My doorbell has numbered buttons that need to be pressed together with the button to open the door, in order to access these functions. Another thought is that a battery needs to be replaced.
2/10/2024 4:57:34 AM • Home Security • Answered on Feb 10, 2024
DSC PTD1640U transformer for the alarm system. Can it be moved?
Question edited for clarity. Question moved from Photo Cameras to Home Security Category. I would caution hiding transformers under a bed because they can get hot, overheat fail and cause a fire. You can certainly use an extension power bar with a a circuit overload breaker in it, but move it somewhere other than under the bed. You could even fix the power bar to the wall a bit higher up and make use of it as long as your daughter knows the dangers of electricity. https://www.google.com/search?q=DSC+PTD1640U+transformer https://www.google.com/search?q=power+bar+with+breaker ..
2/7/2024 11:53:18 PM • Home Security • Answered on Feb 07, 2024
My power flickered off the other day and once it came back on the monitor I use for viewing my cameras has a little white box with a red circle with a red line through the circle.
Presume this is a Security Camera system as opposed to a Sony HandyCam, so I moved it to the Home Security category from 'Power Computers'. The system has lost the feed to the camera because the power flicker was a power disconnect. You should have it on a backup UPS backup. You need to reinstall the camera feeds. Full 'make model (what is is)' in all questions first 3 words. Google make model manual ..
1/28/2024 8:42:43 PM • Home Security • Answered on Jan 28, 2024
How can I reset my floureon h 264?
Press the reset button: Using a small tool like a toothpick or paperclip, press and hold the reset button for a few seconds until the DVR resets. This will restore the DVR to its factory settings, including the default password
1/24/2024 10:45:58 PM • Home Security • Answered on Jan 24, 2024
How do I open my digital safe SKU#P45891 when the number code no longer works?
This sounds like a job for a professional safe cracker.
1/20/2024 10:06:48 PM • Home Security • Answered on Jan 20, 2024
5answers
My jsh safe on reads no date how do i reset it
Have you managed to sort your safe out ? I have the same problem after changing batteries today
1/19/2024 4:41:48 PM • Home Security • Answered on Jan 19, 2024
I have a Micro Fridge Electronic Safe and for some reason it is not opening with my normal code. How do I reset it?
You can make an adapter with a 9 volt battery connector and a telephone module plug
1/13/2024 9:30:31 PM • Home Security • Answered on Jan 13, 2024
Interlogix GE SAW Wireless Indoor PIR Motion Detector Logo
1 questions posted
Top Interlogix Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an Interlogix Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • Interlogix Home Security
Most Popular Question
led light completely off after walk test
  • Home Security
