20 Most Recent Aiwa CDC-X444 CD Player Questions & Answers
manual
My AIWA cd-x444 unit is
it sounds to me like you may have a bad switch. sometimes if you get a switch that does not open all of the way, it sends a message to the microprocessor and locks it up. when this happens, the switch needs to be replaced.
3/10/2011 5:16:32 PM • Aiwa CDC-X444 CD... • Answered on Mar 10, 2011
2answers
System lights up - stuck in demo mode - sometimes CD player plays
if detach face may not be making good contact try removing wipe connections w/rub alchol and put back on
5/23/2010 7:33:28 PM • Aiwa CDC-X444 CD... • Answered on May 23, 2010
I need the citcuit diagram with description of the radioclokreceiver AIWA FR A120EZ BECOUSE REPAIRING!!
You're going to try to fix something but can hardly spell any part of your question correctly... Makes me question giving you a schematic.
2/10/2019 7:06:52 AM • Aiwa Car Audio &... • Answered on Feb 10, 2019
I have a Aiwa head unit in my 2002 volkswagen jetta 1.8t, the power is on but no music is playing from the radio or from my phone. I checked my fuse box but it doesn't have the guide that tells me whi
Hi if the power is on then it is not the car fuse, but the radio itself. I will direct you to the aiwa radio thread.
5/23/2014 5:01:18 AM • Aiwa Car Audio &... • Answered on May 23, 2014
0answers
2answers
Aiwa cdc-x204
try disconnecting the battery to see if that will reset the device. Let me know what the outcome is and we will go from there to fix this. Just make sure to respond here in a timely matter so that we can get you on your way as soon as possible.
good luck
12/23/2012 8:27:56 PM • Aiwa Car Audio &... • Answered on Dec 23, 2012
Fuse for the ash tray for the crysler 300
Fuse #9 feeds the power outlet and fuse #18 feeds the lighter outlet (this is the one I believe your having trouble with).
They are both located in the fuse box in the trunk, next to the battery. If you open the trunk and lift the floor up you'll see them hiding under there. The numbers should be called out on the cover for the fuse box.
9/6/2012 10:36:50 PM • Aiwa Car Audio &... • Answered on Sep 06, 2012
Install instructions pyle pld33mu into chevy impala
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
8/24/2012 3:38:46 PM • Aiwa Car Audio &... • Answered on Aug 24, 2012
When i try to play a cd it tells me to reset the cd how is this done
is your cd player aftermarket or oem if oem look in owners manuel u will have to do a soft reset on the radio if not disconect positive battery terminal and hit the power button a few times wait 2 min and replace cable.
3/27/2012 6:00:14 PM • Aiwa Car Audio &... • Answered on Mar 27, 2012
Ur ***
Please describe the problem . Regards
2/23/2011 8:03:56 PM • Aiwa Car Audio &... • Answered on Feb 23, 2011
What is the best way to retrieve a CD from the
Get two nail files, cover the ends of them with scotch tape, and insert them one at a time so that one goes over the disc, and the other goes under... Press them together firmly and pull slowly while wiggling left and right gently.
This may work, but may not - most CD players have a lock in them, and the disc platter goes up to lock the disc in place as well, so that it can't move while spinning. Depends on the disc's position in the player, really.
8/10/2010 9:12:39 PM • Aiwa Car Audio &... • Answered on Aug 10, 2010
WHEN I PUT THE POSTIVE BATTERY CABLE ON
I'm guessing that you mean the car battery, this is normal on most cars
7/3/2010 2:14:54 AM • Aiwa Car Audio &... • Answered on Jul 03, 2010
Aiwa CDC-X444 CD Player Logo
5 questions posted
Top Aiwa Car Audio & Video Experts
AAA TV Service
AAA TV Service
ADMIN Andrew
ADMIN Andrew
Marvin
Marvin
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Aiwa Car Audio & Video
Most Popular Question
system lights up stuck in demo mode
  • Car Audio & Video
