20 Most Recent
Black & Decker BDOH100 Oil Filled Radiator Heater Questions & Answers
What type of oil is
there is a manual online for the bdoh100...i had to read it myself....just type in the number there and manual and u should find it
My black and decker oil
Have you check the electric receptacle it's plugged into, to see if it's still functioning. Do this either with test leads or by plugging in another electric appliance. If it's not working check your homes circuit breaker panel for a tripped breaker. If you find that's the case, make sure nothing is plugged into the receptacle and reset the tripped breaker. Plug your heater back into that receptacle and see if it trips the breaker. If it does, something in your heater is either overheating or there is an electrical short. In either case, buy a new heater.
EACH TIME I OPERATE MY HEATER, THE SURGE PROTECTOR
Either your heater has a short and that is why iy is popping your surge protector or the surge protector is going bad also check to see how many amps the heater uses and also how many amps your surge protector can handle if you have to much plugged into it then when you fire the heater on it will pop it. Now for the heater I would have it looked at by a professional or buy a new heater sorry for the trouble and thank you for using Fixya!
Hello
How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM •
Heating &...
Answered
on Apr 09, 2024
