20 Most Recent Aiwa XR-C3RW Shelf System Questions & Answers
In all likelihood the Drive belts have snapped. Get them replaced.
Aiwa XR-C3RW... | Answered on Sep 25, 2008
Some guesswork here. If the remote control is specific for the receiver, it should work without any set up required. Just any old Aiwa remote control may not have the necessary code.
Aiwa Audio... | Answered on Dec 21, 2020
check first power supply
Aiwa Audio... | Answered on Dec 04, 2020
Probably something else.
The buzzing is typical of an open circuit input "receiving" radiated 50/60 Hz from nearby mains wiring.
An alternative source of buzzing is the 50/60 Hz mains breaking through into the audio due to failed smoothing and filtering in the power supply.
Capacitors that have been unused for quite a while can lose condition and fail when put into use again and this might have been the cause of the thump/thud/boom you noted.
I doubt it is the cause but it is very unwise to operate an amplifier without a full complement of speakers unless the volume is kept at minimum...
Aiwa Audio... | Answered on Nov 17, 2020
The tape player portion is defective, though new. Many of the site moderators have had that experience.
Aiwa Audio... | Answered on Nov 11, 2020
check more slotjk.com for your solution
Aiwa Audio... | Answered on Oct 24, 2020
You would have to open the unit and check for signal right before headphone plug.
Aiwa Audio... | Answered on Oct 07, 2020
It work as a simple twist action. That small, dark plastic part right in the centre will turn, possible with a small flathead screwdriver.
Aiwa Audio... | Answered on Aug 19, 2020
There's no clear all settings there. You need to manually delete each saved station. Try to unplug the power of the unit for few hours and check if that clears all.
Aiwa Audio... | Answered on Jul 13, 2020
https://www.manualslib.com/manual/3586/Aiwa-Ts-W45.html
Aiwa Audio... | Answered on May 18, 2020
Aiwa XR-C3RW Shelf System Logo
2 questions posted
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Aiwa Audio Players & Recorders
Most Popular Question
cassette player stopped working
  • Audio Players & Recorders
