20 Most Recent
1999 E150 Questions & Answers
1999 ford e150 over heating?
Check you have enough coolant, power wash your radiator, check your radiator cap if the rubber seal os good
8/18/2014 7:24:48 AM •
1999 E150
Answered
on Aug 18, 2014
Ford e150 is leaking somewhere on driver side when it rains?
If it ain't the windows.
It is probably an air vent seal.
Does it leak only when it is being driven or also when it is parked?
Check in front of the windshield - clean out the vents etc... check the gaskets going into the cabin around the wire harness inlets etc.
If you can't find a hole - it might just be condensation from the air conditioner hose.
7/19/2014 4:20:04 PM •
1999 E150
Answered
on Jul 19, 2014
Diesel Pump Rotor Head 1 468 334 337
diesel Pump Rotor Head 1 468 334 337
Item Name(EH)#injector bmw 320d e46#
# head rotor ford 12 mm#
#head rotor ford 187l#
#injector chrysler voyager#
#for injector common rail delphi#
#Ultrasonic Injector Cleaning Machine
#UltraSonic Fuel Injector Cleaning
(EH)China Lutong Parts Plant is a famous manufacturer and supplier specializing in diesel engine parts.We have 30 years experience in this area.
Our aim and business policy is to give the customer a reliable quality product and service, alternative to the OE products. The parts are quality
assured to ISO9001 and are subject to regular internal and external audits ensuring that quality is the highest standard.
nicole(at)china-lutong (dot) net
Wha/tsa/pp:+86133/8690/1375
[email protected]
I have a 1996 ford windstar
They remote is for the immobiliser system. Immobilisers are designed to be VERY difficult to bypass otherwise why fit them? Your simplest solution here is to go to a car key specialist and get a new remote. Once the old one fails the car will not start at all.
Just replace a Ford Falcon AU radio with a
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u
U can also get free manuals
Im having a problem with my remote start. It goes on , but shuts off in 15 seconds. I have a Ford Explorer with a viper alarm.
Just a guess, since some disengage if signal not getting thru that motor running, to prevent starter brushes overheating, burning, etc, and you say motor starts, maybe a dirty electrical connection, like oil or something got in somewhere, interfering with that signal being received. To rule that out I guess yourself or shop, have all electrical connectors looked at for oil, dirt, oxidation, loose, etc... Simply pulling connectors and pushing back on few times might do it if that the issue. Notice if it feels tight or not. If oily dirty, maybe spray male and female parts of connector with alcohol based spray degreaser. Silicone spray has fast evaporating alcohol but the silicone may interfere with electrical connection. Also, be sure your remote button not triggered by weak spring contacting when you set it down or put in pocket as that'll act to shut off if already on. I had 1 get like that. Would park car, head in, putting remote in pocket after going in, would notice car running from inside.
