20 Most Recent
Aiwa NSX-TR77 CD Shelf System Questions & Answers
Vol problem
Here is the entire troubleshooting section from the manual.
Your problem is presumed to be a shorted speaker wire. I assume you're not getting the failure ONLY at extremely high volume levels.
Care and maintenance
Occasional care and maintenance of the unit and the software
are needed to optimize the performance of your unit.
To clean the cabinet
Use a soft and dry cloth. If the unit surfaces are extremely
dirty, use a soft cloth lightly moistened with mild detergent
solution. Do not use strong solvents such as alcohol, benzine
or thinner.
To clean the tape heads
Dirty tape heads cause sound deterioration. After every 10
hours of use, clean the tape heads with a head cleaning
cassette. Refer to the instructions of the cleaning cassette.
To demagnetize the tape heads
Use a demagnetizing cassette after every 20 to 30 hours of
use. Refer to the instructions of the demagnetizing cassette.
Care of CDs
When a CD becomes dirty, wipe it from the center out with a
cleaning cloth. After playing a CD, store it in its case. Do
not keep it in hot or humid places.
Care of tapes
Store tapes in their cases after use. Do not leave tapes near
magnets, motors, television sets, or any source of
magnetism. Do not expose tapes to direct sunlight, or leave
them in a car parked in direct sunlight.
REFERENCE
Troubleshooting
If your unit fails to perform properly, check the following guide
and the relevant sections of the Operating Instructions.
There is no sound.
•Are the speakers and AC power cord connected properly?
The unit shut off suddenly.
•Possibly a short circuit in the speaker terminals.
Disconnect the AC power cord from the AC power outlet
and re-connect the speaker cords correctly.
The unit blacks out when the unit is turned off.
•Is ECO mode set to on?
Erroneous display.
•Reset the unit.
Poor radio reception.
•Check antenna connection. Adjust the antenna to find the
best reception.
•Move unit and antenna away from other electric appliances
and cords.
The tape does not run.
•Is the deck in pause?
Poor tape sound.
•Check for dirty heads. Clean them if needed.
•Use type I (normal) tapes.
Cannot record.
•Is the erasure prevention tab of the tape broken off? If so,
cover the detection slot with adhesive tape.
The CD player works poorly.
•Is the disc correctly loaded?
•Is the disc dirty?
•Is the lens affected by condensation? If so, wait
approximately one hour and try again.
Resetting the unit
If an unusual condition occurs in the display window or the
cassette deck, reset the unit as follows:
1 Press POWER to turn off the power.
If the power cannot be turned off, disconnect the AC power
cord, then plug it in again.
2 Hold down s and press POWER.
Everything stored in memory after purchase is cleared.
CD not working propely
"No disk" is about as fatal a CD read error as ther is. Before we assume the player is at fault let's look at our media. A CD should be handled and cared for like any opitical device. Dirt, fingerprints and scratches are tolerated somewhat but the CD standard isn't impervious to problems.
Do you get any constant results with any CD, say one that always works vs one that never works? Compare them visually for problems on the one that doesn't. I use a clean soft cloth with glass cleaner to clean my media.
This is the entire troubleshooting section for the unit.
Care of CDs
Troubleshooting
There is no sound.
Erroneous display.
•Reset the unit.
best reception.
and cords.
Poor tape sound.
Cannot record.
•Is the disc dirty?
Resetting the unit
Condensation
Moisture may form on the CD pickup lens when:
•The unit is moved from a cold spot to a warm spot
•The heating system has just been turned on
•The unit is used in a very humid room
•The unit is cooled by an air conditioner
When this unit has condensation inside, it may not function
normally. Should this occur, leave the unit for a few hours,
then try to operate again.
Aiwa NSX-TR77
Well Jamez sounds like you have eather blown the soeakers or the output IC's inside the unit. If you have a meter you can simply disconnect the speakers and test the resistance of the speakers with an ohm meter. If you dont have an ohm meter then you can connect them up to another stereo or have them and the unit tested at a repair center. Sorry not really any serviceable parts in these systems. Good Luck
Aiwa Z-L700 cassette player will not work but CD player is fine. Is there a simple solution please?
The complexity of the solution depends on the problem. The drive belt or pinch roller may be worn or have a hardened surface. If the tape doesn't turn at all or only very slowly in any function, verify that the tape drive motor is running and that the belt is turning the pulley(s). If the tape tends to tangle up, check the pinch roller. Sometimes cleaning the roller with a cotton swab dampened with rubbing alcohol will work, but if it's too hardened, you'll need to use rubber conditioner or replace it.
If nothing at all happens when you select the tape function, there may be an electrical problem such as a dirty contact on the function switch or a broken wire in the tape mechanism.
This is far from a comprehensive repair guide; it only covers the most common issues other than broken plastic parts. "Will not work" is too general to provide more than that. Cleaning the pinch roller and its drive pin can be done through an open cassette door; everything else most likely requires taking stuff apart, observing operation and perhaps making voltage measurements.
Need manual for a Aiwa cx_na777
Certainly! Here is a basic manual for the Aiwa CX-NA777:
- Powering On and Off To turn the CX-NA777 on, press the Power button located on the top right of the system. To turn it off, press the same button again.
- Changing the Volume Use the Volume control knob located on the front of the system to adjust the volume. Turn it clockwise to increase the volume and counterclockwise to decrease it.
- Selecting a Source To select a source, such as the CD player or the radio, use the Function button located on the front of the system. Press it repeatedly until you reach the desired source.
- Using the CD Player To use the CD player, press the CD button located on the front of the system. Insert a CD into the tray and press the Play button to start playing the CD.
- Using the Radio To use the radio, select the Radio source using the Function button. Then use the Tuning knob to tune into the desired station. You can also use the Preset buttons to quickly access your favorite stations.
- Using the Tape Deck To use the tape deck, select the Tape source using the Function button. Then insert a cassette tape into the deck and press the Play button to start playing it.
- Adjusting the Sound To adjust the sound, use the Bass, Treble, and Balance controls located on the front of the system. These controls allow you to adjust the bass and treble levels, as well as the balance between the left and right speakers.
- Using the Clock and Timer The CX-NA777 features a built-in clock and timer. To set the clock, press the Clock button and then use the Tuning knob to set the correct time. To set the timer, press the Timer button and then use the Tuning knob to set the desired start and end times.
- Using the Remote Control The CX-NA777 comes with a remote control that allows you to control the system from a distance. The remote control features buttons for all of the main functions, including Power, Volume, Function, and CD playback.
- Troubleshooting If you experience any issues with the CX-NA777, such as a CD that won't play or a radio that won't tune properly, consult the user manual for troubleshooting tips. You can also contact Aiwa customer support for further assistance.
Note: This is a basic manual and may not cover all features of the Aiwa CX-NA777. For more detailed instructions, please consult the user manual that came with your system.
How to turn on mic on aiwa NSX 580?, please.....thank you
To turn on the microphone on an Aiwa NSX-580, you will need to follow these steps:
- Press the "Menu" button on the remote control.
- Use the "up" or "down" arrow buttons to navigate to the "Mic" option in the menu.
- Press the "Enter" button to select the "Mic" option.
- Use the "up" or "down" arrow buttons to navigate to the "On" option.
- Press the "Enter" button to turn on the microphone.
Note that you may need to connect the microphone to the audio system first before turning on the microphone. Also, refer to the user manual for more information.
