20 Most Recent Aiwa XR-EM70 CD Shelf System Questions & Answers
Follow the instructions on page 8 of the manual.
Aiwa XR-EM70 CD... | Answered on Jul 18, 2012
Hi. Firts of all.. chances are that your unit needs to be cleaned or you used low quality cassettes in thr player. a tape has would itself around the capstan and pinch roller causing everything to jam up. you may need to open up the unit..seperate the cassette mechanism from the main chasis and take it apart delicately in order to get the tape out without breaking the door catch .. Use tweezers but do not mark or scratch the azimuth head...OR.. try it from the front and try to open the door with a fingernail in there..while pressing the eject...good luk. Trace Electronics Repair, Canada
Aiwa XR-EM70 CD... | Answered on May 07, 2010
If you have got the original you just need to measure the diameter. Belts are universal and are not generally specfic to one machine.
Aiwa XR-EM70 CD... | Answered on Feb 19, 2010
If you are referring to an aerial antenna that is telescopic, most replacements would be readily available from most electronic supply store. It is a common component and most versions would fit a number of brands and models. Often it is held in place by a single screw. In some instances, an exact replacment may not be available but as earlier stated most would do and serve the purpose. A temporary workaround is to simply put a length of wire to simulate an extended antenna. There are however models/versions that could also accept an aerial even meant/designed for portable TVs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aiwa XR-EM70 CD... | Answered on Aug 28, 2008
Probably something else.
The buzzing is typical of an open circuit input "receiving" radiated 50/60 Hz from nearby mains wiring.
An alternative source of buzzing is the 50/60 Hz mains breaking through into the audio due to failed smoothing and filtering in the power supply.
Capacitors that have been unused for quite a while can lose condition and fail when put into use again and this might have been the cause of the thump/thud/boom you noted.
I doubt it is the cause but it is very unwise to operate an amplifier without a full complement of speakers unless the volume is kept at minimum...
Aiwa Audio... | Answered on Nov 17, 2020
The tape player portion is defective, though new. Many of the site moderators have had that experience.
Aiwa Audio... | Answered on Nov 11, 2020
check more slotjk.com for your solution
Aiwa Audio... | Answered on Oct 24, 2020
You would have to open the unit and check for signal right before headphone plug.
Aiwa Audio... | Answered on Oct 07, 2020
It work as a simple twist action. That small, dark plastic part right in the centre will turn, possible with a small flathead screwdriver.
Aiwa Audio... | Answered on Aug 19, 2020
There's no clear all settings there. You need to manually delete each saved station. Try to unplug the power of the unit for few hours and check if that clears all.
Aiwa Audio... | Answered on Jul 13, 2020
https://www.manualslib.com/manual/3586/Aiwa-Ts-W45.html
Aiwa Audio... | Answered on May 18, 2020
Aiwa XR-EM70 CD Shelf System Logo
5 questions posted
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Aiwa Audio Players & Recorders
Most Popular Question
set time
  • Audio Players & Recorders
