20 Most Recent
Dualit Vario 3 Slices Toaster Questions & Answers
Our Dualit toaster doesn't work.
The
You need to replace the timer-contactor. This part is acting both as timer and electrical contactor. It consist from electrical contact moved with springs on and off. Due to electrical load and extreme heat these contact have been tear out thus they can not contact properly and in your case they don't contact at all.
So from the web page of dualit or ebay you can order A new timer contactor and replace it.
Hi our 3 slice dualit toaster gets stuck when you
We have the same problem and it has been on all day, and credit to the toaster it has not yet burnt out an element, I am looking to replace the timer as I found that the pivot inside is on a plastic bearing and that has worn, I did find a timer on a web site but cant find it now.
I need the elements replacing
Inside your toaster there are six heating element plates four in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
I think the elements are no longer working. can
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red. They can not be fixed.
Good Luck
Recently it has taken longer and longer for pieces
Good Luck
Dualit toaster - timer sticking.
The dualit all electrical parts like elements and timer switch are all manufacture in china and they are not as they used to be. I have a customer with a toaster of 25 years old and we have replace only one heating element up to now. For recent models we replace electrical parts in about 2 to 3 years, some times every year as you describe.
Dualit combi heating element 12/95
All the element's are available on e-bay u.k. for about 6.00 gbp. Alternativley you may be able to repair it. Put the toaster on it's side with the bottom facing towards you and the knobs on the top. Remove the crumb tray and then remove the bottom (usually the screws are located in the feet). There may be one more visible screw remove that too, then you will see a rail at the bottom that secures the element's in place. Loosen off the nuts at each end and slide the rail down, undo the two bolt's feeding the power to the element's and slide the element out.Go over it with a continuity meter and see where it's broken then move the element wire about to bridge the circuit.Test it again and reassemble. I repaired mine this way.Or, simply replace the element using the instructions above.Easy!
Eliment
Did the top element ever work? Perhaps it only works in "broil" setting.
hamar nnelg
Toaster: Dualit Domus DLT44... First one side now the other.. Dead!
Question edited for clarity, added full stops as Fixya removes formatting and line breaks.
Question moved from Cars and Trucks to correct make category.
The latching is normally dependent on the element working. If you have a multimeter, test continuity of the elements. replacing them is normally not easy as domestic toaster use crimped wires direct to the elements cassette. I have a brand new one in my garage for a Black and Decker toaster with 18 crimp wire tails.
I used Dualit and Rowlett commercial toasters at my hotel in Cornwall, England, and they were easy to repair, but Domestic toasters are really a non repairable / replacement option. Ask Dualit what they think?
https://www.dualit.com/support/domus-4-slot-toaster
