20 Most Recent Alpine MRD-M605 Car Audio Amplifier Questions & Answers
Do you have the remote wire hooked up to the acc. on the ignition?
Alpine MRD-M605... | Answered on Sep 17, 2010
Hi, If you mean clipping on/off to be cutting out, then there are a few causes for this.
1) overloading the output circuits.
2) speaker wires shorting to earth/each other.
Try running 1 set of speakers at a time.
P.S. giving us a little more information will help profusely i.e amplifier capabilities, how you have the speakers connected. etc.
Alpine MRD-M605... | Answered on Jul 14, 2010
it sounds like you have purchased a unit that does not operate on our wave length, it sounds American, and all i can suggest is be careful where you buy things from mate, sorry, colin.
you need to use a cable negative and positive # 4. the proplem you have is a poor ground.
Alpine MRD-M605... | Answered on Apr 28, 2010
alpine makes amaizing amps... as long as it's matched to the speakers/subs you are going to put on it this amp will last you a very long time... and it will put out amazing power... you won't be disappointed.
Alpine MRD-M605... | Answered on Dec 13, 2009
,ostl lifkly u need to fix that problem
Alpine MRD-M605... | Answered on Oct 20, 2009
Are you sure its the amp??? Try runing the cd without the amp and see if the same problem persists
Alpine MRD-M605... | Answered on Sep 07, 2009
The WAIT is because wrong security codes have been entered previous.
To reset, leave SWITCHED ON....UNDISTURBED for as long as it takes to automatically reset itself.
It may take many hours (as the waiting time depends on how many wrong codes have been entered).....normally though it is only an hour or two.
Alpine MRD-M605... | Answered on Sep 01, 2009
This means too much current, find and eliminate cause of excessie current and turn power off, also possibe power and ground are not big enough .Recommend 4guage wires
Alpine MRD-M605... | Answered on Jun 27, 2009
If your deck is aftermarket; Does it have a dedicated Subwoofer output? if so, check the control in the deck (sub gain). If you are using a factory radio, and a high to low level adapter (speaker wires to RCA), it may be bad (not too uncommon) or check your fader front/rear any difference? Otherwise, you have one of two problems. A bad preamp in the deck or a bad pre amp in the amp. Both are fairly uncommon. More than likely it's a setting. Hope this helps
Hello yte1771,
You can download the manual from Crutchfield.
The "CUR" display is an indication of excessive current and is most likely caused by too low impedance or a fault in the wiring or the amp itself. It's probably not your cap.
Hope this helps.
Alpine MRD-M605... | Answered on May 18, 2009
Hello, First of all with these new Alpine amps everithing adjustable just about is digital, as well as the internal workings of the amp to a point. If you bought this amp new then check your warranty or take it back where you purchased it if you can. Check that your amp is getting an input signal from your head unit. Check your head unit sub output settings, something could have gotten turned off or down. On this paticular amp if there is a problem internaly it would let you know or go into protection mode. You say your sub has ben tested and is good, check again. Hook another speaker up to the amp. Unhook that speaker and try, you never know. Like I said, if the amp is'nt going into protect mode and the digital display is'nt telling you any types of faults then it has to be the input signal. Make sure you are getting a signal. That has to be your problem otherwise amp would be in protect mode. Let me know what you find.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Alpine MRD-M605... | Answered on Feb 12, 2009
The amplifier probably has shorted output transistors. If the amp gives the same error message with the speaker wires disconnected from the amp, the amp needs to be repaired.
Alpine MRD-M605... | Answered on Dec 31, 2007
Alpine MRD-M605 Car Audio Amplifier Logo
26 questions posted
Top Alpine Car Audio & Video Experts
Robert Salgado
Robert Salgado
Jeffrey Turcotte
Jeffrey Turcotte
Marvin
Marvin
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Alpine Car Audio & Video
Most Popular Question
when turn up radio sounds good but its
  • Car Audio & Video
