20 Most Recent Modine Effinity93 - 260,000 BTU - High Efficiency Unit Heater - NG - 93% AFUE - Separated Combustion Questions & Answers
tip
Chanel purse
Chanel purse is considered to be one of the most amazingly stylish purses available in the market. All these purses are made of leather. So, the durability of the purses is guaranteed. Along with that, you are going to get some of the most eye-catching designs and wonderful finish which will surely satisfy your choice.
2answers
No ignition
Many have a small 3A fuse similar to a car type push in fuse on the main board.
11/26/2014 7:42:36 AM • Modine... • Answered on Nov 26, 2014
When was my air conditioner with serial No. 402KAUU00006 / 920Pe - 40200006 - 2UD120 MADE
Absolutely no idea. Try adding make and model in a google search.
10/25/2021 6:22:27 PM • Heating &... • Answered 3 hours ago
MILLER XMT HEL-P6 IS ON SCREEN?
Yes, sounds like you have lost a phase. Likely have a fused disconnect or something along the power source. Remove load wires and check each circuit to ground.
10/21/2021 7:03:26 PM • Heating &... • Answered on Oct 21, 2021
Nordyne Mgha-075abc-01 won't fire
If its a standing pilot, (the pilot flame is always on) then you need to check thermopile/generator. You can find it where the pilot flame is. The flame from the pilot should be heating this device. A thermopile produces about 750 millivolts when heated. This small amount of energy is what powers the gas valve. That is the click you are hearing, the valve trying to open. When a thermopile gets weak, it cannot produce enough power to keep the valve open. The thermopile is replaceable.
10/21/2021 5:55:30 AM • Heating &... • Answered on Oct 21, 2021
Why After changing the filter,the fan symbol keeps blinking and the unit comes on the turn off.
It sounds like the fan is set to circulation. Circulation mode is a fan setting which will automatically turn the fan (only) on and off at preset intervals. Example, On for 10 min/Off for 20 min in a continuous cycle. When circulation mode is turned on, the fan icon will blink, spin, etc., indicating the mode is active. To turn this mode off repeatedly press the fan button until AUTO is displayed.
10/21/2021 5:46:42 AM • Heating &... • Answered on Oct 21, 2021
Where can I get the owners manual and wiring diagrams for a Nordyne heat pump model WSH2BE4M1SP36K ?
Wire diagrams are typically posted right on the equipment. Many times on inside of access doors.
10/19/2021 2:22:51 PM • Heating &... • Answered on Oct 19, 2021
Our armstrong air ultra v advantage 93 comes on and off when we have thermostat in off position and even when we have thermostat disconnected? ?
Have your HVAC technician check your low voltage wiring. If rodents have chewed into it, or if it has otherwise become bared in spots, then the wires could be touching and therefore "shorting out" which will in many cases cause undesired operation of your HVAC unit. that is the ONLY way that I can think of that it could operate by itself with the t-Stat removed, other than possibly the board, which has been, as you stated, replaced. I would have most likely checked wiring first. Most likely it will be somewhere in the wires from the t-Stat to the indoor unit. Sometimes the wire can get caught by something being moved around in a basement attic, etc and get pulled a little too rightly and it will skin bare due to a staple or nail.... Or even against the wood where it goes into the wall either thru the floor or into the attic or even just behind the t-stat
10/16/2021 5:39:47 AM • Heating &... • Answered on Oct 16, 2021
WHAT SEER IS 2002 RHEEM MODEL RBHC-14J11NHH SERIAL M220210324.
12 seer!!!
10/15/2021 6:46:06 PM • Heating &... • Answered on Oct 15, 2021
Lux Thermostat 500 keeps flashing between temperature and date. Not responding
Sounds like you lost 24v. Possibly a clogged drain line and tripped float switch.
10/14/2021 8:33:27 PM • Heating &... • Answered on Oct 14, 2021
Can someone clarify jumper settings on FUH724.
Not familiar with this unit but according to manual it’s the jumper on cd that moves, not the blue in order to decrease heat btus
10/14/2021 6:21:06 PM • Heating &... • Answered on Oct 14, 2021
How do I get the table top heater knob to go past pivot
no info generic answer read instructional manual on unknown heater ---on most usually after 'pivot' believe correct word is pilot you push in and turn to selected setting
10/14/2021 11:25:11 AM • Heating &... • Answered on Oct 14, 2021
Modine Effinity93 - 260,000 BTU - High Efficiency Unit Heater - NG - 93% AFUE - Separated Combustion Logo
2 questions posted
Top Modine Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
Are you a Modine Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Modine Heating & Cooling
Most Popular Question
no ignition
  • Heating & Cooling
