20 Most Recent Alpine IVA C801 Car Video Player Questions & Answers
2answers
Need brain unit and wiring harness
i need a brain unit 4 an alpine IVA-C800 please help!
9/29/2019 10:21:00 PM • Alpine IVA C801... • Answered on Sep 29, 2019
How do i get the navigation to work for the Alpine
CLICK HERE for your owners manual in PDF format.
The iva-c801 is NAV READY... meaning it needs the optional NAV unit... it is not built into the radio.
The NAV unit is an OPTIONAL piece from alpine. If you do not have a seperate brain for the NAV installed SEE THIS LINK - you do not have this feature.
If you have the NAV unit...(p27 of the manual states:)
If an optional Alpine Navigation System is
connected to the IVA-C801/CVA-1006, some of its
functions can be controlled from the IVA-C801/
CVA-1006.
The functions and display indicators available will
vary depending upon the Navigation System
connected. For details, consult your Alpine dealer.
1 Press the SOURCE button. The main menu
screen appears on the display.
2 Rotate the rotary encoder and select "NAVI,"
then press the rotary encoder to execute the
selection.
The Function Guide display changes to show the
same button names as those for the remote
control supplied with your navigation system.
NOTES
When the V. SEL button is pressed while the
Navigation selection mode is being selected in the
VISUAL setting (refer to page 43), the navigation
mode will be directly activated.
If the Navigation mode menu is not displayed on the
main menu screen, select "AUX IN" in the Setup mode
screen and set the Navigation mode to the ON
position.
If you use the buttons displayed, you can control the
navigation system from IVA-C801/CVA-1006 in the
similar way to the remote control operation.
For operation, refer to the Owner's Manual for your
navigation system.
Depending on the navigation system connected to this
unit, some functions and displays may vary.
Let me know if you require further help.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
3/9/2015 1:10:14 PM • Alpine IVA C801... • Answered on Mar 09, 2015
Need to know how to hook up brake light safty
It depends on your car. When the parking brake is engaged, it completes a circuit. You need to find out ifthe wiring for your parking brake is +12 volts or ground.
6/21/2010 5:42:02 AM • Alpine IVA C801... • Answered on Jun 21, 2010
Where does the parking brake wire hook up in order
based on my previous experience with the Alpine Mobile Multimedia Station, 1 wire needs to see 12 volts ie. brake light wire, the other needs to see ground ie. parking brake.
You can hook up the wire that needs 12 volts to either ignition or some other 12 volt source. The other wire needs to be connected to a toggle switch to ground. Then flip the switch as needed to simulate the parking brake and voila...
8/13/2009 6:20:57 AM • Alpine IVA C801... • Answered on Aug 13, 2009
Wire loom for Alpine IVA C801
Ebay has a good seller for these items, specialtyelectronics.  He has all of those fairly inexpensive, I just bought one.  His stuff is genuine, some of the others on ebay have "non-factory" ones.
5/15/2009 10:24:40 AM • Alpine IVA C801... • Answered on May 15, 2009
What will a wiring harnes
Your Best Bet is www.Crutchfield.com
1/4/2009 12:24:05 AM • Alpine IVA C801... • Answered on Jan 04, 2009
2answers
My Alpine 1VA C801
yes all indash dvds are like that you have to run a cut off swith or buy one so it could work when you drive
9/29/2008 4:30:00 AM • Alpine IVA C801... • Answered on Sep 29, 2008
Motorized Screen gets stuck sometimes - Any fix for it?
Mine does this too, it need a new gear for the actual flip out, if you send it to Alpine they will fix it for around 25 to 30$$.
11/12/2007 6:06:43 PM • Alpine IVA C801... • Answered on Nov 12, 2007
What is the color code for the stereo wires in an 08 land rover l
Battery BROWN/LIGHT GREEN(+)IGNITION SWITCH HARNESS
Ignition 1 WHITE (-) IGNITION SWITCH HARNESS
Accessory 1 WHITE/PINK (-) IGNITION SWITCH HARNESS
Starter 1 WHITE/RED (-) IGNITION SWITCH HARNESS
Tachometer WHITE (-) AT IGNITION COIL
Speed Sense YELLOW/GREEN (AC) AT MODULE UNDER PASSENGER SEAT
Parking Lights ORANGE/RED (-) AT MODULE UNDER PASSENGER SEAT
Brake Lights GREEN/BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Power Unlock BLACK (-) AT MOTOR IN DRIVERS DOOR
PowerLock BLUE (-) AT MOTOR IN DRIVERS DOOR
All Door Trigger VIOLET/GRAY (-) IN HARNESS TO RIGHT OF STEERING COLUMN
Trunk Trigger VIOLET/YELLOW (-) AT MODULE UNDER PASSENGER SEAT
Hood Trigger VIOLET/WHITE (-) AT MODULE UNDER PASSENGER SEAT
Headlights-Lo BLUE (-) AT MODULE UNDER PASSENGER SEAT
Wipers-Lo PINK/LIGHT GREEN(-) AT MODULE UNDER PASSENGER SEAT
Trnk Release WHITE (-) AT TRUNK RELEASE SWITCH
Battery RED/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground TAN (-) RADIO HARNESS
Illumination GRAY/BLUE (+) RADIO HARNESS
LF Speaker (+) BLUE/WHITE
LF Speaker (-) TAN/WHITE
RF Speaker (+) RED
RF Speaker (-) TAN/RED
LR Speaker (+) RED/GREEN
LR Speaker (-) TAN/GREEN
RR Speaker (+) BLUE
RR Speaker (-) TAN/BLUE
Radio Security YES
(thats for 07 but shoe to what u need)
11/21/2022 7:05:53 AM • Alpine Car Audio... • Answered on Nov 21, 2022
How can I get out of demo mode in alpine cde 153bt after I take the battery cable and return
When you first turn on the Alpine CDE-153BT after restoring power, Demo Off displays for 30 seconds. While this is displayed, press Search/Enter (the center of the rotary ring). See page 9 of the manual. To permanently avoid the Demo Mode, see below. If you didn't press the button in that time, you need to enter the Setup menu. Press and hold Audio/Setup (the button is to the upper left of the rotary knob) for at least 2 seconds. Use the rotary encoder (knob) to get to General and press Enter. Navigate through the menu options to Demo Mode. Press Enter. Use the rotary knob to change the setting and press Enter to save. This is described on page 21. To ensure that the receiver does not return to Demo Mode On when the battery is disconnected, choose Quite Off, instead of Off. Then press Enter. (This is covered on page 22 of the manual.) The manual is available from Alpine Electronics here: https://support.alpine-usa.com/products/documents/OM_UTE-52BT_CDE-153BT_EN.pdf . I hope this helps. Cindy Wells
9/30/2022 11:36:48 PM • Alpine Car Audio... • Answered on Sep 30, 2022
Alpine 3552 amplifier manual
This is so so so f-ing ridiculous....I just can not find a picture of the inside of this Amp there is an orange wire on THE INSIDE OF THIS ALPINE 3552 DUO B CIRCUIT 4,3,2, AMP that is coming from 3 different places and tied to gether with a nother wire that was sticking out of the Amp my instinct tells me,... it's orange so probably needs power,,so I gave it power and the Amp come on but the light is orange not blue or green....and being on for a couple of minutes it shuts off ..I CAN NOT FIND A PICTURE OR WIRING DIGRAM OR SCHUMATIC the only pic I can find is to dam blurry to even see the wires uuuuuuuuhhhhhhgggggg
9/15/2022 9:16:30 AM • Alpine Car Audio... • Answered on Sep 15, 2022
Alpine 7164 cassette deck wirring
https://www.repco.com.au/en/in-car-technology/car-audio/facia-kits-and-wiring-harnesses/aerpro-radio-wiring-harness-alpine-to-iso-16-pin-app8alph/p/A9391632# get a universal wiring harness then you get what every car you have universal harness and plug them together talk to a car accessory shop about this universal wiring harness for the alpine unit and then ask if you need a universal harness for the car you have .
8/28/2022 11:51:37 AM • Alpine Car Audio... • Answered on Aug 28, 2022
Bought a car from Japan with Alpine X9NX2 headunit. Unfortunately, all is in Japan. Can I somehow switch language to English?
Some units are only in Japanese because they are specifically for the Japanese home market. There is a trick. Get a smartphone with the Google Translate App on it and use the camera feature to translate what is seen on screen. Look for Settings / Language. https://www.google.com/search?q=alpine+x9nx2+change+language+to+english ..
7/16/2022 9:46:38 PM • Alpine Car Audio... • Answered on Jul 16, 2022
Alpine IVA C801 Car Video Player Logo
17 questions posted
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Alpine Car Audio & Video
Most Popular Question
  • Car Audio & Video
