20 Most Recent
Alpine CDE-7853 Questions & Answers
Speakers only wanna come on
It definitely sounds like it's hooked up wrong (or you have damaged speakers, whis is not real likely). what kind of vehicle is it in? Did you use a store bought harness made for that vehicle?
How do you set stations and clock
1.Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 .Press and hold any one of the Preset buttons (1
through 6) for at least 2 seconds until the
station frequency on the display blinks.
3. Press the Preset button into which you wish to
store the station while the frequency display is
blinking (within 5 seconds).
The display stops blinking once the station has
been memorized. The display shows the band,
preset No. with a triangle (9) and station
frequency memorized
http://vault.alpine-usa.com/products/documents/OM_CDM-7854.PDF
is link to full manual
How do i set the radio stations on a alpine cde
seek the station u want and then press and hold the number u want that station on to. u will hear a beep sound which indicates that station is stored at that number. do the same up to the capacity offered by the radio.
I put a cd in and it will show what track the cd
sounds like you are running through an amp. if you are, you may have the amp remote turn on connected the the power antenna lead instead of the amp remote turn on lead. this should be a blue with a white stripe wire.
Lcd display
You may wish to visit the lounge and read some of the post in there first for your own benefit.
-how do I set the clock
hit display for clock. hold display down till clock flashes. press 5 for hour. press 6 for minutes. hit display again when done
Set time
hit display for clock. hold display button down till screen flashesclock . push 5 for hours. push 6 for minutes.
Clock setting problem
hold display down till it is flashing on screen. push 5 for hours. push 6 for minutes.
How can i plug my mp3 player into my alpine
Get a cd/aux adapter from an alpine dealer, this will change your cd changer input on the back of the radio to a RCA input, then get yourself a Y adapter, and head phone adapter, and you are set..
Alpine CDE 7853 removal
remove the face and then the trim ring for face you should see 2 little pins on either side of the radio slide them up and it should slide right out
I need a Manual for a Alpine Vie-x077 in English and also anyone know why it keeps saying the disc needs to be ejected but it won't
- Mechanical Issue: There might be a mechanical problem with the disc drive or the eject mechanism. It's possible that a part is jammed or not functioning correctly.
- Dirty or Damaged Disc: If the disc is dirty, scratched, or damaged, the player may have difficulty reading it and thus not ejecting it properly.
- System Error: There could be an internal error within the player's software or firmware causing it to not recognize the disc properly or to malfunction when attempting to eject it.
- Power Issue: Sometimes, power-related issues can affect the functionality of electronic devices. Ensure that the player is receiving adequate power and there are no loose connections.
Here are some troubleshooting steps you can try:
- Turn off the player and then turn it back on to see if it resolves the issue.
- Try ejecting the disc using the manual eject button (if available). This button is usually a small pinhole near the disc slot. You can insert a paperclip or a similarly sized object into the hole to manually eject the disc.
- If possible, try using a different disc to see if the problem persists. If other discs work fine, then the issue may be with the original disc.
- Check for any visible obstructions around the disc slot and remove them if present.
- If none of the above steps work, you may need to contact Alpine customer support for further assistance or consider taking the player to a qualified technician for repair.
My Alpine CDE-W235BT bluetooth has stopped working
Se o Bluetooth do seu Alpine CDE-W235BT parou de funcionar ap?s uma falha durante a atualiza??o, pode haver algumas etapas que voc? pode tentar para resolver o problema:
1. **Reinicie o Aparelho:**
- Desligue o r?dio por alguns minutos e ligue-o novamente. Isso pode reiniciar o sistema e resolver problemas temporariamente.
2. **Restaurar as configura??es de f?brica:**
- Consulte o manual do usu?rio para descobrir como realizar uma restaura??o das configura??es de f?brica em seu Alpine CDE-W235BT. Isso pode resolver problemas causados por configura??es incorretas.
3. **Verifique a vers?o do firmware:**
- Se poss?vel, verifique a vers?o do firmware do seu Alpine CDE-W235BT. Se houver uma vers?o mais recente dispon?vel, considere atualizar novamente o firmware, seguindo rigorosamente as instru??es do fabricante.
4. **Remova Dispositivos Pareados:**
- No menu Bluetooth do r?dio, remova todos os dispositivos pareados anteriormente e, em seguida, tente parar novamente. ?s vezes, problemas de conectividade podem ser resolvidos removendo e pareando novamente os dispositivos.
5. **Atualiza??es de Software:**
- Verifique se h? atualiza??es de software dispon?veis para o seu Alpine CDE-W235BT no site do fabricante. Caso existam, siga atentamente as instru??es para realizar a atualiza??o.
6. **Contate o Suporte T?cnico:**
- Se as solu??es acima n?o resolverem o problema, entre em contato com o suporte t?cnico da Alpine. Eles podem fornecer assist?ncia espec?fica para o seu modelo e orienta??es adicionais para resolver o problema.
Lembre-se de que mexer no firmware e nas configura??es do dispositivo envolve riscos, e ? sempre recomend?vel seguir as instru??es fornecidas pelo fabricante para evitar danos permanentes ao aparelho. Se voc? n?o se sente confort?vel fazendo isso por conta pr?pria, procurar ajuda profissional pode ser uma op??o.
Alpine tdm 7543. Is this a model that can switch from green to red lighting?
After researching, it appears that there is no direct evidence suggesting that the Alpine TDM 7543 stereo unit has the ability to switch from green to red lighting. This is an older unit and specific information can be challenging to find. Your best option to get a definitive answer may be to directly contact Alpine's customer service or refer to the original instruction manual.
