20 Most Recent Alpine TDA-7554 Questions & Answers
How do you activate the AUX function
This unit should recognize the connection between the deck and the changer without any problems. Are you sure the plug is compatible with alpine unit?
11/8/2013 4:39:47 AM • Alpine TDA-7554 • Answered on Nov 08, 2013
manual
TDA-7554 Manual
Alpine Car Audio & VideoUploaded on Oct 23, 2013
0answers
Require Instruction Manuel
Hello :
Check here please : http://safemanuals.com/zearchres_28.php
Maybe a manual from the same manufacturer could be helpful .
good luck .
rate please .
3/19/2010 1:31:13 AM • Alpine TDA-7554 • Answered on Mar 19, 2010
Irratic / intermittent power connection, either
loose connection inside radio could be possible, or too many items pulling off that circuit. Ive seen in some radios that have a rotary volume knob wear out and cause intermitten problems in general power and volume areas.
9/15/2009 1:10:27 AM • Alpine TDA-7554 • Answered on Sep 15, 2009
How do you remove an Alpine 7554R from a 1995 mondeo.
The plastic trim was held on, not in the modern way,by a clip in the centre of both sies of the radio/ cassette, which is part circular in shape. This opens up and fits round a pin on the side of the radio, steady pressure with a small screw driver will ease this off, but be carefull not to break the side clipse off, as I think they will be irreplaceable now.I haven't seen a plasic trim held on the same way before. The radio will now slide out of the case as there are no clips as there are on newer alpine models
8/31/2009 9:25:54 AM • Alpine TDA-7554 • Answered on Aug 31, 2009
I need a Manual for a Alpine Vie-x077 in English and also anyone know why it keeps saying the disc needs to be ejected but it won't
  1. Mechanical Issue: There might be a mechanical problem with the disc drive or the eject mechanism. It's possible that a part is jammed or not functioning correctly.
  2. Dirty or Damaged Disc: If the disc is dirty, scratched, or damaged, the player may have difficulty reading it and thus not ejecting it properly.
  3. System Error: There could be an internal error within the player's software or firmware causing it to not recognize the disc properly or to malfunction when attempting to eject it.
  4. Power Issue: Sometimes, power-related issues can affect the functionality of electronic devices. Ensure that the player is receiving adequate power and there are no loose connections.
Here are some troubleshooting steps you can try:
  • Turn off the player and then turn it back on to see if it resolves the issue.
  • Try ejecting the disc using the manual eject button (if available). This button is usually a small pinhole near the disc slot. You can insert a paperclip or a similarly sized object into the hole to manually eject the disc.
  • If possible, try using a different disc to see if the problem persists. If other discs work fine, then the issue may be with the original disc.
  • Check for any visible obstructions around the disc slot and remove them if present.
  • If none of the above steps work, you may need to contact Alpine customer support for further assistance or consider taking the player to a qualified technician for repair.
3/2/2024 3:22:33 PM • Alpine Car Audio... • Answered on Mar 02, 2024
My Alpine CDE-W235BT bluetooth has stopped working
Se o Bluetooth do seu Alpine CDE-W235BT parou de funcionar ap?s uma falha durante a atualiza??o, pode haver algumas etapas que voc? pode tentar para resolver o problema: 1. **Reinicie o Aparelho:** - Desligue o r?dio por alguns minutos e ligue-o novamente. Isso pode reiniciar o sistema e resolver problemas temporariamente. 2. **Restaurar as configura??es de f?brica:** - Consulte o manual do usu?rio para descobrir como realizar uma restaura??o das configura??es de f?brica em seu Alpine CDE-W235BT. Isso pode resolver problemas causados por configura??es incorretas. 3. **Verifique a vers?o do firmware:** - Se poss?vel, verifique a vers?o do firmware do seu Alpine CDE-W235BT. Se houver uma vers?o mais recente dispon?vel, considere atualizar novamente o firmware, seguindo rigorosamente as instru??es do fabricante. 4. **Remova Dispositivos Pareados:** - No menu Bluetooth do r?dio, remova todos os dispositivos pareados anteriormente e, em seguida, tente parar novamente. ?s vezes, problemas de conectividade podem ser resolvidos removendo e pareando novamente os dispositivos. 5. **Atualiza??es de Software:** - Verifique se h? atualiza??es de software dispon?veis para o seu Alpine CDE-W235BT no site do fabricante. Caso existam, siga atentamente as instru??es para realizar a atualiza??o. 6. **Contate o Suporte T?cnico:** - Se as solu??es acima n?o resolverem o problema, entre em contato com o suporte t?cnico da Alpine. Eles podem fornecer assist?ncia espec?fica para o seu modelo e orienta??es adicionais para resolver o problema. Lembre-se de que mexer no firmware e nas configura??es do dispositivo envolve riscos, e ? sempre recomend?vel seguir as instru??es fornecidas pelo fabricante para evitar danos permanentes ao aparelho. Se voc? n?o se sente confort?vel fazendo isso por conta pr?pria, procurar ajuda profissional pode ser uma op??o.
2/16/2024 6:59:12 PM • Alpine Car Audio... • Answered on Feb 16, 2024
Alpine tdm 7543. Is this a model that can switch from green to red lighting?
After researching, it appears that there is no direct evidence suggesting that the Alpine TDM 7543 stereo unit has the ability to switch from green to red lighting. This is an older unit and specific information can be challenging to find. Your best option to get a definitive answer may be to directly contact Alpine's customer service or refer to the original instruction manual.
1/16/2024 5:53:53 PM • Alpine Car Audio... • Answered on Jan 16, 2024
Did MA Audio make a 10 dual 8 ohm subwoofer?
mr david,i recommend inspecting the subwoofer's voice coils visually for any signs of damage, such as tears or burns, and r double-checking your wiring connections
8/14/2023 11:26:27 AM • Alpine Car Audio... • Answered on Aug 14, 2023
9answers
I need the radio code
the number is in your car manual on a card usally about 4 digits
6/28/2023 12:31:30 PM • Alpine Car Audio... • Answered on Jun 28, 2023
Manual for Alpine 7164 AM/FM cassette please?
There is an Owner's Manual for $80 on eBay. Also Service Manuals. They were fitted to Porsche. https://www.google.com/search?q=alpine+7164+manual ..
5/20/2023 2:02:15 AM • Alpine Car Audio... • Answered on May 20, 2023
Alpine CDA 7878R - Hi Temp - won't play disc
Does it play the tuner but not the CD?
If it so, the problem is directly related to the CD deck. If not, the problem could be a sensor or any number of other components that may have overheated.
Try to reset the unit. Most of the time this error is an electrical problem not fixable by the end user. But it is worth trying to reset the microprocessor and see if that helps.
Here is a diagram of where the reset button is at. Press it in with the tip of an ink pen or paperclick, whatever you have that will fit into the little hole. Just hold it in a couple of seconds. Be advised that when yo reset the unit, you will loose all things in memory like the correct time, preset radio stations ect.
If this does not help you will need to have it checked out by a good repair center. These Alpine radios are very good radios and are worth getting fixed unless the estimate is close to what you paid for it.
good luck, I hope this helps. if so, a good rating would really be appreciated. You can always ask me for more help if you need it. I have been repairing car and home audio equipment for over 17 years.
3/21/2023 9:35:39 PM • Alpine Car Audio... • Answered on Mar 21, 2023
Car Audio & Video Logo
Popular Tags
12 questions posted
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Alpine Car Audio & Video
Most Popular Question
activate aux function
  • Car Audio & Video
