20 Most Recent Alpine CTA-1505 Questions & Answers
Press and hold the INTLZ button for at
least
3 seconds.
Notes:
Initial mode is "SUBW OFF."
Set to "SUBW OFF" unless the
subwoofer is used.
When the subwoofer is turned on, the
subwoofer output level can be adjusted.
For more details, refer to the Adjusting Volume/Balance/Faderhope this solves youre problem found it in the manual.
Alpine CTA-1505 • Answered on Jan 20, 2013
you supposed tu turn mute off and the pink cable to ground
Alpine CTA-1505 • Answered on Mar 04, 2008
Does your Alpine support the ALPINE AI NET adapter?
If so, this will work;
http://www.installer.com/item/display_item.php?it=alp-ai-35mm
Otherwise, you might want to get an FM Transmitter;
http://www.amazon.com/Griffin-White-iTrip-Transmitter-iPod/dp/B0000AAAPF
Best of Luck.
Please RATE my solution BELOW.
Alpine CTA-1505 • Answered on Nov 25, 2007
Hello eklypss2000,
According to the manual for the Alpine CDE-102, the message "DC ERROR" is displayed if there is a short to ground in the speaker wiring. Check all of your speaker wires and make sure that no bare wire is shorting against the vehicle metal or against other wires. Repair or replace the wire as necessary. After correcting the problem, set POWER IC to "POW ON" according to the instructions in your manual.
Hope this helps.
Alpine Car Audio... • Answered on Feb 04, 2021
Page 29 of the manual https://www.manualslib.com/manual/1277562/Alpine-Ivx-W200e.html?page=29
Alpine iVX-W200E - AAV - Automotive Audio Visual
www.aavaus.com.au > ... > Alpine iVX-W200E
The iVX-W200E provides an impressive range of multimedia compatibility all through the touch of the immaculate 6.2" screen. Enjoy full entertainment with USB ... A$249.00 · ‎In stock
Download Software - Alpine
www.alpine-electronics.co.za > support > download-sof...
You must agree to the following terms and conditions before downloading the software tool and bluetooth firmware update. The present Software License Terms ...
Alpine IVX-W200E ' Aerpro
aerpro.com > headunit > alpine > ivx-w200e
Alpine IVX-W200E. The parts illustrated here allow you to connect this aftermarket headunit to the Vehicle Specific harnesses and infodapters detailed on each ... ..
Alpine Car Audio... • Answered on Jan 31, 2021
What is the code of bontec alpine a06012 car stereo
Alpine Car Audio... • Answered on Nov 03, 2020
Frankie. I am having the same problem. Did you find an answer or do I need to get a new power pack or control unit?
Alpine Car Audio... • Answered on Aug 15, 2020
I can't find the power wires on my Alpine CDA 7894
Alpine Car Audio... • Answered on Apr 17, 2020
Is this a custom instal? If yes, Check that the amps are powering up. You may need to check the fuse for the amps or the remote wire fuse. It could have blown hooking up the new battery. If there are no amplifiers check both fuses for the Alpine deck unit.
Alpine Car Audio... • Answered on Jan 07, 2020
Unless other specified in paperwork, all Alpine receivers are 4ohm capable only.
Now yes there are exceptions, but not many.
Now for amp almost all alpine amps can be run in several different resistances.
Basically for sure 4ohm, now depending on model some have abilities to go as low as 1ohm stable. But for most 2 ch alpine non special amps are all 4ohm and most 2ohm capable.
Now better models can do things such as run 2,3,4 ch. And some can even get to .5 ohm loads stable.
Alpine Car Audio... • Answered on Oct 16, 2019
Do you have an external amp? Give me more info on stereo going in, and what it does do.
Car Audio & Video Logo
Popular Tags
3 questions posted
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Alpine Car Audio & Video
Most Popular Question
cta 1505 auxiliairy input
  • Car Audio & Video
