20 Most Recent Alpine CDE-7826P Questions & Answers
Clock setting for Alpine CDE-7826P
Push the clock button until it flashes. Then push '5' for hours, '6' for mins until you get to desired time.
11/8/2014 10:03:02 PM • Alpine CDE-7826P • Answered on Nov 08, 2014
manual
CDE-7826P Manual
Alpine Car Audio & VideoUploaded on Oct 23, 2013
Hey I have a alpine cde-7826 receiver its not
Please check carefully the format the CD you burn. Your player should has at least same format or better to make it read the CDs.
For example standard dvd player will not able to read mpeg 4 CDs.
Regards
3/13/2011 12:07:14 AM • Alpine CDE-7826P • Answered on Mar 13, 2011
Powers down
get a bigger power supply
7/29/2009 5:18:23 PM • Alpine CDE-7826P • Answered on Jul 29, 2009
Alpine CDE0-7826P Cd Player doesn't always work
If It dosent play burned cds its not an mp3 compatiable cd player as far as the other problem kinda seems like its time for a new cd player
6/14/2009 3:15:15 AM • Alpine CDE-7826P • Answered on Jun 14, 2009
Cd player
how do i set the time on my cde7826p reciever
9/5/2008 4:56:16 PM • Alpine CDE-7826P • Answered on Sep 05, 2008
Need wire diagram for alpine 3319
Wiring diagram for 3319 alpine equalizer
9/11/2024 6:59:01 AM • Alpine Car Audio... • Answered on Sep 11, 2024
How many watts does the vie xo77 screen have
That depends on what specification of power amplifier you plug it into.
9/9/2024 6:44:50 AM • Alpine Car Audio... • Answered on Sep 09, 2024
Alpine EX9V Car Stereo. How do I change the language from Japanese to English?
If it was a Japanese Import it may only come in Japanese, because it is for the Home market. Often that requires a new Firmware download. In others it needs a Software upgrade and finally, some just need to change the settings. What you can do is find an iPhone with the Google Translate App, and use the Camera Feature to translate what you see onscreen. Look for Settings - Language. https://www.google.com/search?q=change+my+Alpine+EX9V+car+stereo+from+Japanese+to+English https://www.google.com/search?q=EX9V+ALPINE+Car+Harrier ..
7/12/2024 2:29:29 AM • Alpine Car Audio... • Answered on Jul 12, 2024
I need a Manual for a Alpine Vie-x077 in English and also anyone know why it keeps saying the disc needs to be ejected but it won't
  1. Mechanical Issue: There might be a mechanical problem with the disc drive or the eject mechanism. It's possible that a part is jammed or not functioning correctly.
  2. Dirty or Damaged Disc: If the disc is dirty, scratched, or damaged, the player may have difficulty reading it and thus not ejecting it properly.
  3. System Error: There could be an internal error within the player's software or firmware causing it to not recognize the disc properly or to malfunction when attempting to eject it.
  4. Power Issue: Sometimes, power-related issues can affect the functionality of electronic devices. Ensure that the player is receiving adequate power and there are no loose connections.
Here are some troubleshooting steps you can try:
  • Turn off the player and then turn it back on to see if it resolves the issue.
  • Try ejecting the disc using the manual eject button (if available). This button is usually a small pinhole near the disc slot. You can insert a paperclip or a similarly sized object into the hole to manually eject the disc.
  • If possible, try using a different disc to see if the problem persists. If other discs work fine, then the issue may be with the original disc.
  • Check for any visible obstructions around the disc slot and remove them if present.
  • If none of the above steps work, you may need to contact Alpine customer support for further assistance or consider taking the player to a qualified technician for repair.
3/2/2024 3:22:33 PM • Alpine Car Audio... • Answered on Mar 02, 2024
My Alpine CDE-W235BT bluetooth has stopped working
Se o Bluetooth do seu Alpine CDE-W235BT parou de funcionar ap?s uma falha durante a atualiza??o, pode haver algumas etapas que voc? pode tentar para resolver o problema: 1. **Reinicie o Aparelho:** - Desligue o r?dio por alguns minutos e ligue-o novamente. Isso pode reiniciar o sistema e resolver problemas temporariamente. 2. **Restaurar as configura??es de f?brica:** - Consulte o manual do usu?rio para descobrir como realizar uma restaura??o das configura??es de f?brica em seu Alpine CDE-W235BT. Isso pode resolver problemas causados por configura??es incorretas. 3. **Verifique a vers?o do firmware:** - Se poss?vel, verifique a vers?o do firmware do seu Alpine CDE-W235BT. Se houver uma vers?o mais recente dispon?vel, considere atualizar novamente o firmware, seguindo rigorosamente as instru??es do fabricante. 4. **Remova Dispositivos Pareados:** - No menu Bluetooth do r?dio, remova todos os dispositivos pareados anteriormente e, em seguida, tente parar novamente. ?s vezes, problemas de conectividade podem ser resolvidos removendo e pareando novamente os dispositivos. 5. **Atualiza??es de Software:** - Verifique se h? atualiza??es de software dispon?veis para o seu Alpine CDE-W235BT no site do fabricante. Caso existam, siga atentamente as instru??es para realizar a atualiza??o. 6. **Contate o Suporte T?cnico:** - Se as solu??es acima n?o resolverem o problema, entre em contato com o suporte t?cnico da Alpine. Eles podem fornecer assist?ncia espec?fica para o seu modelo e orienta??es adicionais para resolver o problema. Lembre-se de que mexer no firmware e nas configura??es do dispositivo envolve riscos, e ? sempre recomend?vel seguir as instru??es fornecidas pelo fabricante para evitar danos permanentes ao aparelho. Se voc? n?o se sente confort?vel fazendo isso por conta pr?pria, procurar ajuda profissional pode ser uma op??o.
2/16/2024 6:59:12 PM • Alpine Car Audio... • Answered on Feb 16, 2024
Alpine tdm 7543. Is this a model that can switch from green to red lighting?
After researching, it appears that there is no direct evidence suggesting that the Alpine TDM 7543 stereo unit has the ability to switch from green to red lighting. This is an older unit and specific information can be challenging to find. Your best option to get a definitive answer may be to directly contact Alpine's customer service or refer to the original instruction manual.
1/16/2024 5:53:53 PM • Alpine Car Audio... • Answered on Jan 16, 2024
Did MA Audio make a 10 dual 8 ohm subwoofer?
mr david,i recommend inspecting the subwoofer's voice coils visually for any signs of damage, such as tears or burns, and r double-checking your wiring connections
8/14/2023 11:26:27 AM • Alpine Car Audio... • Answered on Aug 14, 2023
9answers
I need the radio code
the number is in your car manual on a card usally about 4 digits
6/28/2023 12:31:30 PM • Alpine Car Audio... • Answered on Jun 28, 2023
Car Audio & Video Logo
12 questions posted
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Grand Canyon Tech
Grand Canyon Tech
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Alpine Car Audio & Video
Most Popular Question
powers down
  • Car Audio & Video
