20 Most Recent
Alpine CDM-7835 Questions & Answers
7835 pre set stereo
tune to station ,press (for example)1 and hold till it starts blinking , then press 1 again,continue in this manner until you've set all presets.
Alpine 7835 display lights not working, everything else is fine
if it's not under warranty, I would advise taking the face plate apart and checking for burned spots on the board and using compressed air to remove anything that is conductive that may cause a short in the face plate. The face plate should be really easy to take apart.
I have an alpine cdm7854
some radios all you have to do is tune to station you want and hold down the button 123456 on the radio for five seconds good luck....
Alpine CDM 7854
my solution is, that you so called experts don't know squat, so you try to get people to pay
19.99 a head to set stations on a stereo
CD-7835 MANUAL
Here's a link to Alpine's manual download page for your model:
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=CDM-7835
Pre set stations
Here's a link to the manual download page at Alpine. It should tell you everything you need to know.
I need a Manual for a Alpine Vie-x077 in English and also anyone know why it keeps saying the disc needs to be ejected but it won't
- Mechanical Issue: There might be a mechanical problem with the disc drive or the eject mechanism. It's possible that a part is jammed or not functioning correctly.
- Dirty or Damaged Disc: If the disc is dirty, scratched, or damaged, the player may have difficulty reading it and thus not ejecting it properly.
- System Error: There could be an internal error within the player's software or firmware causing it to not recognize the disc properly or to malfunction when attempting to eject it.
- Power Issue: Sometimes, power-related issues can affect the functionality of electronic devices. Ensure that the player is receiving adequate power and there are no loose connections.
Here are some troubleshooting steps you can try:
- Turn off the player and then turn it back on to see if it resolves the issue.
- Try ejecting the disc using the manual eject button (if available). This button is usually a small pinhole near the disc slot. You can insert a paperclip or a similarly sized object into the hole to manually eject the disc.
- If possible, try using a different disc to see if the problem persists. If other discs work fine, then the issue may be with the original disc.
- Check for any visible obstructions around the disc slot and remove them if present.
- If none of the above steps work, you may need to contact Alpine customer support for further assistance or consider taking the player to a qualified technician for repair.
My Alpine CDE-W235BT bluetooth has stopped working
Se o Bluetooth do seu Alpine CDE-W235BT parou de funcionar ap?s uma falha durante a atualiza??o, pode haver algumas etapas que voc? pode tentar para resolver o problema:
1. **Reinicie o Aparelho:**
- Desligue o r?dio por alguns minutos e ligue-o novamente. Isso pode reiniciar o sistema e resolver problemas temporariamente.
2. **Restaurar as configura??es de f?brica:**
- Consulte o manual do usu?rio para descobrir como realizar uma restaura??o das configura??es de f?brica em seu Alpine CDE-W235BT. Isso pode resolver problemas causados por configura??es incorretas.
3. **Verifique a vers?o do firmware:**
- Se poss?vel, verifique a vers?o do firmware do seu Alpine CDE-W235BT. Se houver uma vers?o mais recente dispon?vel, considere atualizar novamente o firmware, seguindo rigorosamente as instru??es do fabricante.
4. **Remova Dispositivos Pareados:**
- No menu Bluetooth do r?dio, remova todos os dispositivos pareados anteriormente e, em seguida, tente parar novamente. ?s vezes, problemas de conectividade podem ser resolvidos removendo e pareando novamente os dispositivos.
5. **Atualiza??es de Software:**
- Verifique se h? atualiza??es de software dispon?veis para o seu Alpine CDE-W235BT no site do fabricante. Caso existam, siga atentamente as instru??es para realizar a atualiza??o.
6. **Contate o Suporte T?cnico:**
- Se as solu??es acima n?o resolverem o problema, entre em contato com o suporte t?cnico da Alpine. Eles podem fornecer assist?ncia espec?fica para o seu modelo e orienta??es adicionais para resolver o problema.
Lembre-se de que mexer no firmware e nas configura??es do dispositivo envolve riscos, e ? sempre recomend?vel seguir as instru??es fornecidas pelo fabricante para evitar danos permanentes ao aparelho. Se voc? n?o se sente confort?vel fazendo isso por conta pr?pria, procurar ajuda profissional pode ser uma op??o.
Alpine tdm 7543. Is this a model that can switch from green to red lighting?
After researching, it appears that there is no direct evidence suggesting that the Alpine TDM 7543 stereo unit has the ability to switch from green to red lighting. This is an older unit and specific information can be challenging to find. Your best option to get a definitive answer may be to directly contact Alpine's customer service or refer to the original instruction manual.
