20 Most Recent PANDIGITAL PANSCN05 Photo Scanner with 512MB SD Card White Questions & Answers
Where can I purchase the negative adapter. I have misplaced mine
search on amazen.com
6/30/2014 7:56:46 PM • PANDIGITAL... • Answered on Jun 30, 2014
Why My trittOn warhead 7.1 headset port keeps blinking
Hi, There are a couple things that could blink on a Tritton Warhead 7.1 headset: 1. The round quadrant on the base station 2. The sync button on the headset piece itself On 1. That means you have to sync it with your Xbox. Press the button on the Xbox that you would usually pres to sync a controller (it kind of has 3))) on it) and then press the sync button on the base station. they should sync up, then you have to press the ( 3 ))) ) ones on the inside of the headset until the quadrant on the Base Station is the same as on your controller. 2. that means that the headset is not connected to the base station. Try to unplug it form the power socket but if you get no lights on the base station at all it might be faulty or the power adapter might be faulty You get 2 yars of warranty from the purchase date so submit a ticket on support.madcatz.com
1/28/2015 7:41:27 PM • PANDIGITAL... • Answered on Jan 28, 2015
0answers
Import usb
Be the first to answer 2/3/2014 5:15:10 AM • PANDIGITAL... • Posted on Feb 03, 2014Be the first to answer
0answers
0answers
0answers
Film won't load on Vectis 300 MinoIta
The clue is in your descrition; Old. If the mechanism has jammed, due to age or lack of use that causes tarnisg=hing on the contacts, the motor/mechanism will not load. I would get it serviced at an aurgorised Minolta repair shop. Contact Minolta for a list of authorised repairers.
3/22/2024 7:04:40 AM • Photography • Answered on Mar 22, 2024
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
  1. Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
  2. File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
  3. Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
  4. Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
  5. Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
3/16/2024 9:30:07 AM • Photography • Answered on Mar 16, 2024
PANDIGITAL PANSCN05 Photo Scanner with 512MB SD Card White Logo
3 questions posted
Top PANDIGITAL Photography Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
View Most Popular
  • PANDIGITAL Photography
Most Popular Question
purchase negative adapter misplaced
  • Photography
