20 Most Recent Acer P235H LCD Monitor Questions & Answers
Acer P235H monitor goes off on it's own after 3-4 seconds
to the hyjackers, see thisposted 100s of times, on old CCLF monitors.not many this old are good, a fact.in all cases above not one person told what PC this was.So my answer is based on this monitor fails on ALL PCsfor sure 1 that is known to be good.(and not stuck in sleep mode or hibernate mode.here is 60 test below( magic flashlight test)http://www.pcdied.com/monitors_and_screens/flash-light-trick.html
12/13/2018 9:12:15 PM • Acer P235H LCD... • Answered on Dec 13, 2018
Good evening I have a
I don't know which OS you have but there is a power management setting and most likely in their it is set to switch the monitor to sleep mode
1/7/2018 6:10:06 PM • Acer P235H LCD... • Answered on Jan 07, 2018
Repare kit for power suplay acer p235h
There is no power supply. There is a power cable and a data cable.
7/20/2014 3:41:00 PM • Acer P235H LCD... • Answered on Jul 20, 2014
0answers
P235h
Be the first to answer 6/10/2012 2:06:39 AM • Acer P235H LCD... • Posted on Jun 10, 2012Be the first to answer
My monitor is running normally, but the power
Possible that the processor sectionhas encountered a fault and since the processor is not working the customer panel controls are not active. Unless the panel is removed and the main board is taken out the processor cannot be checked. Sometimes it can be due to moisture build up, if so use a heater to warm up. Also check the +5 to the processor before we can go further.
11/8/2011 4:30:21 AM • Acer P235H LCD... • Answered on Nov 08, 2011
Hi, I have the Acer
What happens after the welcome screen?
4/13/2011 7:41:27 AM • Acer P235H LCD... • Answered on Apr 13, 2011
Blurred lines on my computer screen
the ribbon-cables that connect the panel to the control board were damaged.. try taking it apart and disconnecting the panel and re connectinng it..
hope this helps
2/7/2011 3:22:28 AM • Acer P235H LCD... • Answered on Feb 07, 2011
3answers
Installed new Acer P236H to a few years old
What device-resolution combinations is your computer's video-card capable of? 1024 by 768 by 60 Hz? 1024 by 1024? Anything that matches that "native" resolution of the ACER?
You may need to upgrade your video-card, to support the "native" resolution of the ACER.
1/15/2011 3:06:23 AM • Acer P235H LCD... • Answered on Jan 15, 2011
My new-bought Acer Aspire 3 has yellow acer logo when starting up, is it normal? Because in some yt videos, the acer logo is green
Perfectly normal. It depends on the internal timing of the GPU and the OS version.
4/17/2024 3:01:26 AM • Acer Computers &... • Answered 2 days ago
tip
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
2answers
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER. this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done. Acer X1110 data projector Standard throw projector.. did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2) did you read owners manual page 32 yet, errors. LED codes.? there are 4 LED, and all 4 matter, projector turned (ON) (not one =1) also in pairs glowing and also if blinking or not, so read page 32 it tells all that. my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,. color-undefined-undefined-0.jpg https://manualzz.com/doc/49497108/acer-x1110-user-manual some have dust filtler a shop first cleans is out first, and check fan RPM with and LED tachometer. this is all SOP.
4/2/2024 4:37:58 PM • Acer Computers &... • Answered on Apr 02, 2024
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
1/25/2024 8:38:32 AM • Acer Computers &... • Answered on Jan 25, 2024
Gud day my motherboard model is acer b25h4-am pc i forgot the password in bios so i decided to clr_cmos jumper and take out the cmos battery to clear the password of my bios,
I would try starting up and go straight into the BIOS. Set up your system and reboot.
1/23/2024 7:25:53 AM • Acer Computers &... • Answered on Jan 23, 2024
2answers
I can't use bluetooth on my Acer Aspire 7520
This computer does not have Bluetooth capabilities and you can't make it, by adding a Bluetooth Driver. It would need a Bluetooth transmitter and receiver HARDWARE built into the computer at the time of manufacture.. https://icecat.biz/en/p/acer/lx.akg0x.146/aspire-notebooks-aspire+7520-6a2g16mi-1376542.html and this site actually says it. https://www.bhphotovideo.com/c/product/538918-REG/Acer_LX_AN20X_017_Aspire_7520_5757_Notebook_Computer.html/specs Wireless Wi-Fi: 802.11b/g Bluetooth: None ..
11/27/2023 12:05:13 PM • Acer Computers &... • Answered on Nov 27, 2023
Acer 7240 turns off when unplugged
bad battery
10/21/2023 9:29:10 PM • Acer Computers &... • Answered on Oct 21, 2023
CCFL Laptop Screen Inverter
If Laptop is ok and screen is ok then I suggest check the ribbon cable connectors. Are all wires ok ? For information, CCFL Service manual is here https://clubelectronicos.com/wp-content/uploads/2020/11/lg_inverter_t-con_board_repair.pdf and Acer Aspire 8930G Service manual is here Acer Aspire 8930G Service Manual (Page 107 of 119) ' ManualsLib
10/18/2023 1:07:27 PM • Acer Computers &... • Answered on Oct 18, 2023
Acer P235H LCD Monitor Logo
13 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • Acer Computers & Internet
Most Popular Question
installed new acer p236h few years old
  • Computers & Internet
