20 Most Recent Apex Digital AT2708 27" TV Questions & Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Unlock procedure to many popular brand TVs are given.
Apex Digital... • Answered on Aug 12, 2014
Without remote control, you can't unlock it. To know more about how to unlock a TV, check the site linked here. Unlock procedure to many popular brand TVs are given. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Type in the brand name of your device in the search box, and press "Enter". Universal remote controls are available at most of the electronic spare part selling shops.
Apex Digital... • Answered on Jul 29, 2014
i believe your sleep timer is still set.. go to the menu and find your sleep timer options turn on or off with volume buttons..that should help
Apex Digital... • Answered on Apr 26, 2012
V stands for vertical output. You have a vertical collapse. Go back to service menu, and set range for vertical. Or you can try factory reset.
Apex Digital... • Answered on Nov 28, 2011
Hello
Your apex TV has been locked. To unlock it you must have its original remote control. Do the following to unlock it
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
1. To use the override code:
2. Hit the MENU key to get to the menus.
3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code. No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired OK.
Apex Digital... • Answered on Aug 16, 2011
I have red key on the front of my tv screen and am not able to turn it on. Please help. my email is [email protected]. Pleae notify me of solution.
Apex Digital... • Answered on Mar 03, 2011
You have to hold the button that looks like a flag (top left) and press either the mute or video button. I don't remember which one
Apex Digital... • Answered on Feb 27, 2011
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Apex Digital... • Answered on Jan 24, 2011
Hello
OK
Happy New Year
Apex Digital... • Answered on Dec 31, 2010
Please view this FixYa Tip which gives the full breakdown on how to unblock the Apex parental lock.
If the solution works, please remember to leave a vote for it.
Thanks.
Apex Digital... • Answered on Feb 07, 2010
The screen lock has been activated. Thankfully there is a simple solution. Please view this FixYa Tip.
If the problem is resolved please do take a moment to rate the solution and thanks for using Fixya.
Apex Digital... • Answered on Jan 11, 2010
Apex Digital AT2708 27" TV Logo
Popular Tags
48 questions posted
Top Apex Digital Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Apex Digital Televison & Video
Most Popular Question
tv red key in corner
  • Televison & Video
