1. To use the override code:
2. Hit the MENU key to get to the menus.
3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code. No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired NB: You may have its original remote remote control handset to do this. In rare cases, some universal remote handset also will work with. OK.
Apex Digital Televison & Video • Uploaded on Aug 25, 2013
SUPER BAND(J~W)
HYPER BAND(AA~ZZ, AAA, BBB) ULTRA BAND(65~94, 100~125)If the signal of your cable provider do not have in these ranges, you must have toconnect a converter.http://www.dataentryjobs.us/67948.html
Captions will appear at either the top or bottom of the screen while a captioned broadcast is received.
When you select the Text (T1-T4) mode, the TV can receive teletext signal.
When you select "CCD/Text Off ", the CCD / Text function is off.
3)Press the CC button to turn on/off the CCD/Text mode
OK.
15 questions posted
193 Questions
97 Questions
59 Questions
